  • SN95 4.6L Mustang Tech
another octane question
  • Thread starter Thread starter reezy
  • Start date Start date Sep 7, 2004
R
reezy
21
  • Sep 7, 2004
ok i usually put premium fuel in my stang but recently i put in 87 and my car is slower..i mean i will punch it in 2nd gear around 30 mph and it will pull slowly...but when i do the same with 91 it pulls so much quicker..the reason i am wondering is because i have read a bunch of threads explaining that if there are no significant power mods added than premium is a waste of money...yet i have nothing but a catback and my car just pulls faster with 91...anybody with me on this one??
Venom_Nitrous
416
Spearfish, SD
Sep 7, 2004
  • Sep 7, 2004
dunno why, but I get more power plus about 4 more mpg with premium. Do the math. It pays.
Sick96Stang
621
Gilbert, Arizona
Sep 7, 2004
  • Sep 7, 2004
Trust me you dont get any more power from the octane rating of the gas you put in your car. Only thing the octane rating means is how slow the gas burns, you get no power gains.
J
JakeDaSnake
43
Mobile Alabama
Sep 7, 2004
  • Sep 7, 2004
I used to run premium in mine but I put a tank of regular in it the other day and it runs better on regular its ran rich on premium... and it wont pull very hard in 2nd from 30mph anyway mine pulls good goin into 2nd at 55mph...
Later
Jake
J
Jakes
84
  • Sep 7, 2004
The long explaination....
A higher octane rating means the mfgr has actually added compounds to the mix to slow down the flame front (burning) of the fuel. This is done to prevent "detonation" or "pinging" or "spark knocking" usually associated with high compression or SC'ing or hot weather (Austin) or a lean condition. Detonation is a bad thing and is to be avoided at all cost.
If your car will run on 87 octane without detonation or pinging, save the extra $ and buy that strut brace you've always wanted.
In fact (you probably won't believe this), if you run premium fuel in an engine designed to run on regular, you will actually lose power. Not really noticable, but because the fuel is burning slightly slower than with regular, it's not generating quite as much pressure and concequently not as much power. In higher compression engines the high compression more than makes up for the slightly slower burn rate of the fuel.
And to all you guys out there that will say, "...but my car runs better or faster or quicker, with premium. God and the petrolium manufactures love you and hope you never stop believing that and giving them your money.
WRXracer
825
  • Sep 7, 2004
couple months ago I helped my friend install PI heads on his 98 GT and when we got his heads off oh my god did he have carbon build up I asked him what octane he runs and he told me 91.. over the years the slow burning 91 octane caused a ton of carbon build up I always run 87 octane in my 01 GT and 93 in my 02 supercharged GT..
3.8L_of_Pain
123
Southern California -- Orange County
Sep 7, 2004
  • Sep 7, 2004
That is a point worth remembering. Higher octane might be required for lower elevations, lean air / fuel ratios, high coolant temperatures, boost, increased compression ratios, and hotter air inlet temperatures. Your EEC can accommodate most of these changes, with the exception of boost and increased compression ratios.
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
V
Where did my seafoam go?
  • Valicy
  • Jan 1, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jan 1, 2024
revhead347
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Dangerous High RPM at stop/ RPM Jump when switching to Neutral then dies.
  • 02torchvert
  • Dec 17, 2023
SN95 4.6L Mustang Tech Jan 3, 2024
Yel2002GTAuto
Y
