another oil question?
03MGT
199
I just changed my oil and I put 5 quarts in and the stick was reading to low so then I put 6 and it read level. I thought the car only took 5 quarts???? By the way its a 2003.
Well officially, 02+ is 6 qts.
My 02 takes 6 qts, but my wife's 01 only calls for 5 qts. In the end, use the dipstick to guage how much to put in. FOr me, I just dump 6 and forget about it.
Yea my 96 takes 6. You have to take filter capacity into consideration. If you change the filter (which you always should), it usually takes one extra quart of oil to fill it up. This has been my experience in every car I've owned.
Edit: And NO I don't mean the filter can hold a full quart of oil.....before someone flames me about that.....lol.
To the people whose car takes 6 quarts. Is your block a Windsor block (8 bolt crank) or Romeo (6 bolt crank)? If the 8th digit in your vin is an X then its a Windsor. Mine is a Windsor and takes 6 quarts, anybody else?
Mine also is a Windsor. Is that supposed to make a difference in the amount of quarts? :shrug: I heard that all 4.6's take 6 quarts. :shrug:
