another what could I run...
I've done some search for cars similar to mine and can't get a decent answer...I've got a 95 cobra, 306, ported cobra heads, 6 lb pullied s-trim, 5-speed, rpm intake, & supporting mods and it made 425/420 at the wheels...
Now the car is full weight (ill pull the spare but besides that) and I'll be leaving on 315 BFG Dragradials...the car has a fresh eaton posi unit w/ 327 gears...
Any ideas? Thanks,
Depending on how well you can drive, I would say anywhere from mid 11's to low 13's. The car should run at least a 12.00 with DR's and a decent 60' time.
Do a search for GMKILLR as he has a similar combo, but with a stock from the TB to oil pan engine and he ran a 11.7 at 118 with a 1.6X 60'.
425 is REALLY good for only 6lbs of boost, what pulleys are you running?
