Antenna delete
  • Thread starter Thread starter Luca11
  • Start date Start date Mar 22, 2011
Luca11
60
Chicago
Mar 22, 2011
  • Mar 22, 2011
Does anybody know of a way to completely get rid of the standard antenna and get a hidden antenna with actual reception!!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 22, 2011
  • Mar 22, 2011
Well you can remove the stocker from the fender and weld up the hole etc, then route the antenna to a wire antenna. The problem i've had is just finding an antenna to do this with.
MahFiVeOh
531
9
49
Ontario, Canada
Mar 22, 2011
  • Mar 22, 2011
You could always just do the "Antenna mod" Remove the ball on top of the antenna and trim the antenna to what ever length you want. The ball is pressed on btw.
PS I did this to mine.
aar0s
1,015
55
69
Mar 22, 2011
  • Mar 22, 2011
seems like i saw an antenna that was wound in the fender one time so there was no external antenna.
If and when i paint my jalopy im doing the antenna delete with the plug like on the 93 R. I never listen to it anyway.
Adams91LX
689
12
29
Plano, TX
Mar 22, 2011
  • Mar 22, 2011
i took mine off, fiberglass-ed over it, then bondo'd smooth...
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Spare tire orientation?
  • Bib36`
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
JD1964
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
