CHANGING BRAKE PADS
Scwhitten
46
9
18
Ocala, FL
So, in my 01 GT, when installing brake pads, you have to, apparently, turn the plunger thingy in order to get it around the new pads. One side, no problemo. The other side, no matter how much I turn it, it does not go in enough to get around the new pads...freaking frustrating!!!
Anybody know why this is happening (or not happening) and how can I get it in JUST A HAIR more? It seems like no matter how much I turn it, it just laughs at me.
Please help...
Thank you.....
You talking about pushing the pistons back into the caliper? If so, you need to use a c clamp with the old brake pad to press both pistons in at the same time.
Reactions: DadLife0724
You trying to use a cube tool or a real piston turning tool like this?
If it truly won't budge, it may be seized and need replacing, but you can try a fee things to persuade it. Make sure the parking brake is fully loose. Crack open the bleeder, as sometime pressure can cause the piston to fight you. Obviously, you'll need to ensure you bleed it to ensure there's no air, which you'd need to do replacing the caliper anyways. Work it back and forth and tap on ghe caliper body lightly with a hammer. Hopefully, you can clear it up. Otherwise, time to replace.
In the kit that FastDriver posted, you will notice two turning mechanisms. One is left hand thread, the other is right hand thread.
Are you sure that you are turning the piston in the right direction? It may be a left hand thread piston. I have run into that before.
One other thing to look at, sometimes the pads are labeled "inside" and "outside" and have to be installed in the correct location.
If they are not installed in the correct location, then the caliper will not go on. Take the pads off of both sides and inspect closely to insure that there are no differences in the pads, or if there are, try installing them in a different location.
  • Useful
Rear calipers screw in; fronts push. At the age of these, not uncommon to have a seized caliper. rebuild or replace with reman ones. Had to do that same on all 4 corners of my mach last year and it only has 104k. Just sits so they were not functioning and very sticky.
If you feel it went in correctly then measure the new brake pads to ensure they are same thickness side to side.
I wish I had one of those tools. But the piston turns fine, just doesn't seem to move inward. I may replace the caliper anyway. Thank you for responding.
I never thought I might be turning it the wrong way since it is on the other side. I'm praying that's what it is...after my morning coffee. The pads did look identical, but that's the first thing I'll check if turning the other direction doesn't bring me happiness. Thank you for your response.
Righty tighty, lefty loosy for both sides. turn right on both sides to screw in. If it's turning but not screwing in, then it needs replaced.
Yeah, I turn it ccw and it comes out. Turn it cw and it goes in to a certain point, but not enough to get around pads. Frustrating.
Guess I’m calling junkyards
Mustang5L5, I just ordered said tool at Amazon. Will get it tomorrow. It did make sense that you might have to push while turning and I don't have a tool that would do that...until tomorrow. Fingers crossed. Thank you for your advice, I will let everybody know what happens, because I know everybody is dying to find out... ;-)
I am still trying to fix my fuel pump issue...turn key on and pump primes, but never stops. New pump. Car starts wonderful, but fuel pump never shuts off and it can be heard from several feet away. In all my 37,000 relocations around this great country, why can't I ever move near a guy, or gal, that wants to stop by and troubleshoot with me? I have beer! Soda! Water! Pizza! Sighhhhhh.....thanx in advance.
Fuel pump relay or whatever the circuit is called in your car
If that doesn't work, then let's just skip to the end... it's a megasquirt setting.
