My motor is almost finished. Im down to putting the lifters, pushrods, rockers intake and carb on. The machine shop i took it to asked if i was using regular roller lifters, or anti pump-up lifters. I asked them what the difference was, and they said that at higher RPMs it prevents floating the valves or something along those lines. he said also that at idle, i might get some "clacking" sounds. ive never heard of these or know if they are right for me or not. Also, any guesses to what i should be shifting around with this setup? ill list the mods below.
Stock block 302 bored .030 over (rotating assembly balanced)
TFS 10:1 forged pistons
Eagle Rods
Eagle Steel Crank
Eddy Air Gap Intake
Holley 650 DP carb
TFS stage II cam
New Cam thrust plate
FRPP balancer
TFS 6.700 pushrods
TFS TrackHeat Heads (out of the box)
Scorpion 1.6 rockers
Double roller timnig chain
Melling standard volume oil pump, pickup & ARP oil pump driveshaft
New stock oil pan
MAC 1 5/8 equal length shorties
O/R H pipe
(rest of exhaust undetermined as of yet)
Super King Cobra Clutch
Resurfaced flywheel
All new ARP botls holding everything together
T-5 rebuilt with Hanlon internals
Stock rear end (3.08's)
Thanks in advance for any input
Eagle Rods
Eagle Steel Crank
Eddy Air Gap Intake
Holley 650 DP carb
TFS stage II cam
FRPP balancer
TFS 6.700 pushrods
New stock oil pan
O/R H pipe
Resurfaced flywheel
