Anti Theft ideas?
  • Thread starter Thread starter THX 138
  • Start date Start date Oct 31, 2005
1 of 2 Next Last
T
THX 138
375
Los Angeles
Oct 31, 2005
  • Oct 31, 2005
I bought one of those clubs you put on the brake or clutch pedal. so brake in my case. Do you think a fuel cutoff valve in the trunk is a good idea or will people see me going in my trunk all the time and figure it out? what about putting it on a remote controlled solenoid?
68 Coop
104
Mesquite, NV
Oct 31, 2005
  • Oct 31, 2005
Remove the coil wire, and she ain't moving.
rbohm
6,698
550
204
tucson,az
Nov 1, 2005
  • Nov 1, 2005
what you need is a system of things, hidden switches, line loc for the rear brakes, fuel cut off. removing the coil wire doesnt really help these days as thiefs either carry one with them, or make use of a plug wire and just run on 7 cylinders.
if you use hidden switches, you will need at least 3 of them. remember that where you hide the switches, thiefs have likely already looked. if you use three of them you can deter them to the point where they are taking too much time to get the car going, and move on to a different and easier target.
i forget who, but there is a company that makes a line lock for the rear brakes. you install it in the rear line, and when you park the car you hold the brake pedal down and lock the rear brakes in place.
you can still use a fuel cut off switch, but use one that is activated electrically, and put it on its own circuit. that way you can hide the switch. again you might use at least two switches to activate it.
you might also use a seperate switch to activate the starter instead of using the ignition switch.
98CobraClone
592
Ripley, Ohio
Nov 1, 2005
  • Nov 1, 2005
I've seen the battery shutoff's installed inline with the chassis ground cable, out of sight, near the motor mount. Also seen people remove their shift knob, as long as it's push button, it's a pain in the rear to get in gear.
If you have an electric fuel pump, the shut off is an idea, but it may be better to try to disable to ignition system, or both at the same time.
Just some ideas
jerry S
1,365
52.22N 5.12E
Nov 1, 2005
  • Nov 1, 2005
removable steering wheel, kill switch, and Lo-Jack.
M
mustangman70
1,235
St pete, Florida
Nov 1, 2005
  • Nov 1, 2005
If you use a MSD box or the like you can wire up a spark cut off switch in combination with the box, so WHEN the switch is flipped the MSD wont put out spark...thats what i did
gonzothegreat
421
London (uk)
Nov 1, 2005
  • Nov 1, 2005
Do you have any websites showing how to do that please?
DarkoStoj
929
Detroit
Nov 1, 2005
  • Nov 1, 2005
basically the way these cars are stolen is a thief putting a wire lead from the 12v battery terminal to the + side of the coil, then jumping the solenoid to start the car, and he's gone. So that wouldn't do anything.
You have to find ways to make the car take longer to steal which would visually deter thiefs to move onto another target. The brake pedal club you have is good, but I'm too lazy to use that.
I like having a systematic way of cutting out the power to the electric fuel pump that only you would know how to do.
ashford
485
fargo ND
Nov 1, 2005
  • Nov 1, 2005
i like the electric fence hooked to the drivers seat idea.
one idea i had was to isolate the starer solonoid from ground via rubber etc. and hooking your horn switch to the solonoid for a ground, one downside though your horn dont work with the steering wheel.
something that would work too is to have an msd box with a remote rev limiter chip for 700rpm with a high stall converter.
thehueypilot
1,084
Medina,Tennessee
Nov 1, 2005
#10
  • Nov 1, 2005
  • #10
Just some ideas
On the same idea they make a battery disconnect that mounts on the battery's negative post, but if you remove the big green knob it would be hard to jump across it w/o having a heavy gage wire in hand or a spare green knob.
latamud
791
Tampa, FL
Nov 1, 2005
#11
  • Nov 1, 2005
  • #11
This is not a good idea. The solenoid runs off battery power and will drain it. Line locks are for smokey burnouts, which last seconds. Leaving the line lock on too long will fry the solenoid. But, they can be good for passing a safety check for those states that need them if your e-brake doesn't work. Find a shop that lets you stay in the car. They'll have you pull the ebrake and at that moment set the line lock. viola!
19stang66
689
#12
  • Nov 1, 2005
  • #12
where can you buy these switches and cutoffs and such that you keep talking about? or does anyone have a write-up of how to install these? i'm not the most talented electrical kid on the block.
P
pj1
57
Calif
Nov 2, 2005
#13
  • Nov 2, 2005
  • #13
What if you lock the hood.
Under the hood, put a remote controlled alarm system. Most of these systems have a power on/off terminal. Connect this terminal to the coil.
If the alarm is set, then no power to the coil. Deactive the alarm and everythings good.
I'm also putting the battery & solenoid in the trunk. That way they would have to supply their own hot lead. (assuming they got into the engine compartment)
What do ya think?
PJ
LMan
1,246
Mom's basement
Nov 2, 2005
#14
  • Nov 2, 2005
  • #14
5.0ina66
664
Ohio
Nov 2, 2005
#15
  • Nov 2, 2005
  • #15
Right on Lman! I'm thinking about getting some tiny stickers made to put in the vent windows that say "This vehicle protected by Smith&Wesson" Besides, if I shared my anti-theft "secrets" here, any idiot gooling could find them and know how to steal MY car
--Kyle
LMan
1,246
Mom's basement
Nov 2, 2005
#16
  • Nov 2, 2005
  • #16
"Notice: Driver Carries Only $20.00 Worth of Ammunition"
T
ttoney
195
Denver
Nov 2, 2005
#17
  • Nov 2, 2005
  • #17
Free with car: 14 warning shots to the head.
5.0ina66
664
Ohio
Nov 2, 2005
#18
  • Nov 2, 2005
  • #18
In Soviet Russia, 4 shots to the back of the head was considered suicide.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Nov 3, 2005
#19
  • Nov 3, 2005
  • #19
i heard of an idea that involved the cigarette lighter, you need to push it in for the car to start, but i dont remember the specifics......coil wire, starter switch, or something....
85 Turbo Bird
77
Sacramento, CA
Nov 3, 2005
#20
  • Nov 3, 2005
  • #20
you can make a fuel cut-off that's operated by a hidden magnetic switch. So when you get in the car you wave your "magic wand" over the hidden switch (behind a panel or something) and start it up.
1 of 2 Next Last
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
