Anti-theft ideas?
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
There's a good thread on here about anti-theft ideas but I can't find it. I'd like to put a hidden switch for the fuel pump so I can turn it off when I leave the car in a parking lot. That way it would start but just die...
Any other ideas and what would be the best way to cut off the fuel pump? I was thinking about just cutting the wire going to the inertia (sp?) switch?
thanks
i use a fuel pump cut off switch and a starter kill switch, plus a dummy switch that is in plain sight. that way if they break in and it won't start, they hit the dummy switch. when nothing happens they give up. ( in theory anyway ) i just cut into the red wire going to the fuel pump and ran it to a toggle switch hidden in the car's interior, same basic principle for the starter. cheap insurance.
Regardless how much stuff you do if they want it bad enough they'll get it. You can just make it as inconvenient as possible.
For years people have put a toggle switch under the seat and removed things like the fuel pump relay or disconnect the TFI module.
If you do a search you will find that this topic has been covered thousands of times.
Follow this tech note for the best way to wire a fuel pump kill or anti-theft switch...
On 86- 91 cars the fuel pump relay is under the seat, 92 and later cars, the fuel pump relay is under the Mass air duct on the passenger fender well.
Note that the wire colors changed in 1991, so there are two different descriptions.
86-90 model cars:
Cut the red/black wire going to the fuel pump relay. Splice a 16 or 18 gauge wire into the wire and connect it to one side of the switch. Connect the other side of the switch to the other end of the red/black wire going to the fuel pump relay. When you are done the switch should be in the middle of the spliced red/black wire that goes to and comes from the fuel pump relay. Using the control side of the circuit allows you to use light gauge wire and light duty switches. There is less than 1 amp going through the circuit, so you don’t have to worry about voltage drop across the wiring depriving the fuel pump of electrical power.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model wiring diagrams.
91-93 model cars:
Cut the Lt Blue/Orange wire going to the fuel pump relay. Splice a 16 or 18 gauge wire into the wire and connect it to one side of the switch. Connect the other side of the switch to the other end of the Lt Blue/Orange wire going to the fuel pump relay. When you are done the switch should be in the middle of the spliced Lt Blue/Orange wire that goes to and comes from the fuel pump relay. Using the control side of the circuit allows you to use light gauge wire and light duty switches. There is less than 1 amp going through the circuit, so you don’t have to worry about voltage drop across the wiring depriving the fuel pump of electrical power.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model wiring diagrams.
See the attached document for a pedal lock that makes it impossible to drive the car.
we should make a sticky of anti-theft ideas cause I always wonder about them and someone always ask's about them.
I also think the quick reelese hub for the steering wheel would be a good one and it will have that race car look.
The only way to make it anti theft would be to have a vehical body guard or VBG. Their job would be to sit in your car and beat the sh@! out someone opening their door into your car or scooping it out to see what's in it.
Well my little buddy in the avitar and his little brother take good care of the house...may look like a dufuss but he (they both do really) has a nasty streak a mile wide when anyone comes a knockin and I'm not home...so I've been told on several occasions. Guess you could call them my house/garage security system.
the98stang said:
I'm sorry but if a car theif wants your car enough, their going to steal it no whatter what.
Just do the fuel cut off switch, and garage it if you can. And of course, have full insurance coverage ;)
how about a
REMOVABLE STEERING WHEEL??
how are they gonna take it then? steer it with vice grips:rlaugh:
GREYFOX4INCH said:
how about a
ah don't worry they'll get it....are you familiar with towing? If they want it they'll get it nicely or not, remember it's not the car they want most often, it's the parts...any damage done while 'attaining' the car is not something they are going to worry about.
I'm going to do the fuel cutoff thing ASAP. Also going to install one of those pager alarm systems so if it buzzes I'll run outside with a sawed off shotgun.
I'd like to set traps in the car like a 3 inch nail under the seat or something but there's always the "what if I forget, and rip my butt to hell one day" thing lol
I have lost my fair share of Mustangs to car theives (2 to be exact) The most you can do is slow down a theif. Which usually means, if they can't drive it away they will come back with a tow truck and haul it away.
I do a few things to slow the theives down but that is only for my piece of mind really. My only recommendation is doing more than just 1 trick to slow a theif down.
