Any fix for vibration problem?
  • Thread starter Thread starter kdog_x
  • Start date Start date Apr 14, 2005
kdog_x
566
  • Apr 14, 2005
I've had problems with an exhaust leak where the headers meet the H-pipe for quite a while now, even after many attempts to tweak the h-pipe into place. Last week I found out about muffler paste, so I figured I'd give it a shot. I pulled the h-pipe back down for the 50th time and smothered the flanges in paste, put it back together and let it harden for a few hours. I must say, I'm impressed with how well this stuff works, I dont think I'll ever do another exhaust job without it, the exhaust leak is almost completely gone.
Unfortunately, now my car has a bad vibration at ~1900 RPM's in any gear. It sounds and feels like the exhaust is rattling off the floorboards. So I figured OK, I'll slide under there one more time and try to adjust it. I slid under there and the only place I noticed that was close to the floorboards was on the h-pipe towards the rear on the passenger side. So I dropped the pipe again and tried to make for a little more clearance, but after finishing yesterday and going for a ride, it mustn't have been enough because it still has the same problem.
Anyone know of any tricks to make my H-pipe stay put? There's no problems above or below that range, it only does it at about 1800-2000 RPM's. Please help, this problem is extremely annoying :damnit:
slytherin
702
northeast ohio
Apr 14, 2005
  • Apr 14, 2005
Thats a tough one sorry man.
jmitchell38925
22
  • Apr 14, 2005
If the h-pipe is twisting it may possibly be your motor mounts failing.....not a guaranteed fix but you could check it
kdog_x
566
  • Apr 14, 2005
Is there any way to check the motor mounts or is it just a visual thing?
46defense
445
Sanford Fl.
Apr 14, 2005
  • Apr 14, 2005
Did you put the headers on yourself? If so you might be able to remember how much of a gap you had between the headers and the steering shaft. When my mounts started to go bad, my headers starting rubbing on my steering knuckle. Also as far as the leak goes, My Mac headers were only skip welded in about 3 or 4 places where the flange mates up to the pipes, and those skip welds gave out over time. Then the flange was just pulling down and bending as I tightened the h-pipe up on it. My new BBK's were the same way when I got them, but I took them to work and got them welded up solid all the way around. Now I can get that union tight, where before I couldn't and it always seemed like I had a leak. Just something for all you guys to look at if you seem to be having trouble getting them tight and keeping them tight.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
