any guesstimates on what ill be running?
You should be in the mid 14's if you can hook up good and drive. Next mod I'd do if I were you would be an aftermarket intake. Edelbrock/Trick Flow/Cobra. Make your own cold air kit, shifter, bump the timing....stuff like that.
Jake
I'd definatly do a intake and head mod. i'm personally porting and polishing my own heads, and i'l probably do an explorer intake. THAT will make a difference. The only thing left is compression, or induction.
