any one with this set up?
  • Thread starter Thread starter izzleon
  • Start date Start date May 13, 2007
I
izzleon
22
  • May 13, 2007
i have a 93 with .030 over gt40 heads, e303, roller rockers, gt-40 upper and lower. need to ask u some questions if u have this same set up please reply if u do
T
TheUser
1,859
Springfield, MO
May 13, 2007
  • May 13, 2007
My GT has a 306, GT40 P heads, E303, GT40 Lower and Cobra upper. What's your question?
jammer84_03
468
  • May 13, 2007
had the e303 with iron original gt40's, 30 over, ford stamped 1.7 roller rockers
wythors
Get off my lawn!!!
2,277
35
69
C Addle
May 13, 2007
  • May 13, 2007
Mods list
GT-40X303 aluminum heads
Ford Racing Performanc Parts E-cam
FRPP 1.6 roller rockers
Polished Cobra intake
Edelbrock 65mm throttle body
73 mm C&L MAF
Summit Racing cold air induction
FRPP24 lb injectors
BBK adjustable fuel pressure regulator
March underdrive pullies
3.73 rear gears
FRPP Jet-Hot coated unequal length headers
Bassani catted X-pipe
SLP Loudmouth cat-back.
So?
I
izzleon
22
  • May 13, 2007
how much vacuum
i have a few questions, how much vacuum are u getting at idle and higher rpm? compression? u used roller rockers? what size? if u did use rollers did u have to shim them? thanks
T
TheUser
1,859
Springfield, MO
May 13, 2007
  • May 13, 2007
I just rebuilt the engine last year and it's only got about 250 miles on it. Haven't gotten the car out yet, but it should have excellent compression. The cam really doesn't have much to do with compression.
I do not have roller rockers, but you may have to shim, just depends.
If I recall correctly, vacuum was around 14* hg at idle w/ the E303.
I
izzleon
22
  • May 13, 2007
oh man
oh ok then theres some thing wrong with mine. i have about 10 hg. and climbs up at higher rpm
I
izzleon
22
  • May 13, 2007
how's it run?
T
TheUser
1,859
Springfield, MO
May 13, 2007
  • May 13, 2007
It runs pretty well. I rebuilt the engine last summer and only put about 250 miles on it before I put it up for winter, which was back in November. I'm getting it out this week. Perhaps you have a vacuum leak which is what is causing yours to have lower vacuum?
Make sure all of your vacuum lines are hooked up. If you have any vacuum lines that aren't being used, cap them off. Check for leaking gaskets. If I remember correctly, vacuum goes up to about 25 when I hit the throttle, but then quickly corrects and goes closer to 0. At WOT, vacuum is nearly zero, which is how it is supposed to be.
T
TheUser
1,859
Springfield, MO
May 17, 2007
#10
  • May 17, 2007
  • #10
Sorry man, I was wrong. My GT w/ the similar setup to yours idles at about 650 (stock) with about 11 Hg of vacuum. Push the gas, vacuum goes down, let up a little and it jumps up over 20 and bounces a round a bit. I just got the car out yesterday and noticed that, so I thought I'd let you know.
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Suspension UPR Coilover sleeve dosent drop down over strut
  • Creomod
  • May 25, 2025
Fox 5.0 Mustang Tech May 28, 2025
RaggedGT
  • dan50
  • Jul 18, 2026
dan50
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
