Any power guesses?
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Sep 18, 2010
First Prev 2 of 2
Cobra912
1,777
11
39
Wish I was anywhere but here
Sep 20, 2010
#21
  • Sep 20, 2010
  • #21
you saw me with that pipe? I guess 450 is on the weak side, I made that with my little 331/1220 so I re-estimate (is that a word?)
I'll say 550.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Sep 20, 2010
#22
  • Sep 20, 2010
  • #22
I'll say 550.
The thing is, turbos don't suffer from parasitic losses to the extent that superchargers do, specifically from driving the compressor with the belt drive. Turbos typically make more power per pound of boost, so basing a guess on a similar setup using a supercharger will almost always low-ball the result. You can usually get ball-park by taking the NA power of the engine times [1+turbo boost/14.7].
Example: 318rwhp X [1 + (10psi / 14.7psi)] = ~534rwhp
318rwhp X [1 + (15psi / 14.7psi)] = ~642rwhp
642 is probably wishful thinking, especially considering his fuel system.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,240
2,948
224
Vass, NC
Sep 20, 2010
#23
  • Sep 20, 2010
  • #23
Interestingly to me, my car made only 362 rwhp n/a and 762rwhp at 14.5 psi, which is more than double. The difference may have been in the tune, though. A/F for the n/a run was close to 14:1, but just less than 12:1 under boost. I've read stories where boosted vehicles made more power than the formula indicated possible, but I wonder if there's any substance to that. Should it be physically possible (in the scientific manner) for a vehicle to make more than twice the power with less than twice the air if both setups are tuned correctly? There are so many variables when it comes to air-flow that it makes my head spin when I try to work out any semblance of a solution.
M
mwood
177
#24
  • Sep 20, 2010
  • #24
I've never understood spending big money on heads, intake, ..., and then putting in an ots cam. As already recommended, find a custom cam grinder. Discuss your combo and be ready to be told the weak link in your setup. Ask if your should change one thing before a new cam what that would be. Listen. If the cam grinder is worth anything he should have some good advise coming your way. He is also likely to ask of your goals, so think about what those might be. You'll be much happier in the end if you do.
1991notchbackLX
1,483
47
48
New York
Sep 20, 2010
#25
  • Sep 20, 2010
  • #25
Is there an echo in here?
M
mwood
177
#26
  • Sep 20, 2010
  • #26
(goes back up to read)... I guess so. Great minds huh.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Sep 20, 2010
#27
  • Sep 20, 2010
  • #27
My car also disproved that formula, should have made a max of 445 by those numbers at 10psi.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Sep 20, 2010
#28
  • Sep 20, 2010
  • #28
Exactly, there are so many variables in engine thermodynamic principles, no formula can predict anything exactly. For the cars that stray significantly ABOVE the predicted result, I have to believe that something wasn't quite right before the boost, or maybe not "optimal", and then with the boost and/or tune, it was "optimal". Hell, even atmospheric conditions could play into that quite a bit, consider that a lot of people probably don't luck out enough in having the exact same weather the day they dyno NA and the day they dyno on boost.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 20, 2010
#29
  • Sep 20, 2010
  • #29
The tuner is thinking right around 600 WHP,but i didnt ask or did he say if that was with my fuel system.He knows my car as he's the one that tuned my N/A tune.I know the cam is the hold back!I found that out after i bought it and ran the dyno.BUT i did ask on here for suggestions for the cam when i built the N/A motor.But like i said i will be getting a custom grind once i switch to roller (hopefully over the winter),and then onto the fuel system.I will also run the meth Then we'll see if i can take the lower intake off and see if the block will fall apart in 2 pieces?This is part 2 of my 3 part build and part 3 is gonna be some $$$$$$$$$$$$$$$$$$$$$$$$$$$$$ so it might be a year?Or even 2 but it will be worth it! Ben you better step up! I should have everything by this weekend so i'm hoping to dyno the 2nd week of oct. peace
john
bentley429isBAC
922
188
84
CT
Sep 20, 2010
#30
  • Sep 20, 2010
  • #30
FastDriver said:
It's a rare event, but I disagree with you bentley. He's not going to run out of injector at 600rwhp. Now, he didn't mention the fuel pump or the rest of the system. Stock lines would not be appropriate, and even a 255LPH pump is going to be on the ragged edge at best especially at the pressure the system will have to withstand at full boost (55-65psi), but the 60# injectors should be up to task.
Chris
Na your right was having a space cadet moment I guess.
First Prev 2 of 2
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
What power
  • SMOKEDYA
  • Nov 3, 2011
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 4, 2011
Shaolin Crane
How Is This Cam?
  • SMOKEDYA
  • Aug 21, 2012
Fox 5.0 Mustang Tech Aug 25, 2012
vfast
cam selection need advice
  • SMOKEDYA
  • Oct 14, 2009
Fox 5.0 Mustang Tech Oct 16, 2009
strtrcr50
  • Locked
9 Sec All Motor Fox 700hp..trade For Boosted Street Car
  • yoshgixxer
  • Aug 28, 2012
5K
Fox Body Mustangs For Sale (1979-93) Aug 28, 2012
yoshgixxer
