Any reason why...
  • Thread starter Thread starter wythors
  • Start date Start date Apr 27, 2011
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 27, 2011
  • Apr 27, 2011
...I shouldn't put a little tackweld on the back of the stud where it threads into the header? I just scored a screamin' deal ($75) on a like new set of FMS stainless shorty headers. My only complaint about these headers (my third set) is that the stud always comes out when you separate the pipe from the header, due to the self-locking nut. I thought a small tack would remedy that problem and be reversible in the future if needed.
old_blue
1,783
282
124
Apr 27, 2011
  • Apr 27, 2011
the only issue I can really think of is replacing it. If the threads ever become stripped or damage replacing the stud would seem to be a pain even if it is just a tack weld. I have thought about this as well when I had hedman headers but there was no stud and there was a bolt one side with a nut on the other. what a pain that was.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 27, 2011
  • Apr 27, 2011
Remove the stud, cut a hacksaw slot in the end of the stud that threads into the header flange. Looks like a screw head with a 3/8" deep slot when you get finished. Screw the stud back in with the slotted part of the stud in the header flange. Keep tightening the stud until a significant part of the slotted part of the stud sticks out. The take a cold chisel and hammer it in the slot until it spreads out. You have now locked the stud in place without welding it. With some persuasion to shrink the spread apart slot, you can remove the stud if necessary.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 27, 2011
  • Apr 27, 2011
I'd rather deal with the stud coming out.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 28, 2011
  • Apr 28, 2011
I must have not gotten enough sleep last night because I think that's funny....
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 28, 2011
  • Apr 28, 2011
It was kind of intended to be...
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Apr 28, 2011
  • Apr 28, 2011
If you just put a tiny dot of weld on the stud, you could easily grind it off if you needed to take the bolt out. If you're accurate with your welds, i don't see a problem with it. Just put it where it's easy to get to with a grinder to make it easy on yourself if you ever do need to grind it off and don't over do it.
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
On3 Performance Install Tips
  • flstang65
  • Dec 15, 2019
12K
1996 - 2004 SN95 Mustang -General/Talk- Mar 17, 2023
atomicfox236
A
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
