Any trick to replacing the struts on a 90?
91conv
59
fenton, mi
Sorry for the basic question, I have only done shocks on 4 corners in the past.
I'll be doing shocks and struts on the 90 conv very soon, hoping this will solve the 'low on divers side front' situation I have. She only has 140K on her.
Thanks
there is a good chance that replacing the struts won't fix the problem. They don't support any weight....
but anyway, take off the front wheels, move the calipers to the side. put a jack under the control arm to make sure it doesn't drop down. Then, get a big ass breaker bar with a pipe on the end, and take the huge bolts out of the lower strut mount. They were torqued to 150-180ft*lbs from the fractory, and probably have not moved in 13 years. Then, you have to get the upper strut nut off. An impact wrench should make it easy... otherwise, it is difficult to keep things from rotating. Then, reverse the process. Take off all the bushings and covers, and put them back on the new strut the way they came off. Be sure that you don't bung up the metal rod, or the seals in the new strut will go out.
Do you think Ill need to replace the spring also? From the sound of it =, it doesn't seem like there is much more work involved.
Thanks for the reply.
