Any tricks to getting a U-Joint off?
Cobra1894
196
Broken Arrow, OK
I have a Ujoint that is connecting my yoke that will not come off. I have the yoke off but I need to remove the ujoint from the driveshaft. I tried brut force and knocking the holy crap out of it, but I dont want to damage the Dshaft. Any tricks anyone knows of?
There is a special tool used to press it out, you can probably rent it.
I wouldn't be banging on too many things related to the driveshaft, that's what causes and unbalance.
Try using a ball joint press. It is a big C-clamp with adapters. Autozone rents/loans them out here.
I have also used the 4# hammer method but it kinda sucks if the caps are stuck.
be sure to put the DS back in indexed per your removal markings.
Good luck.
pb blaster works wonders. i use a big clamp or a socket that it the same size or slightly smaller than the cap itself and lay the driveshaft in the grass. hold the socket on the cap and whack it with a big hammer.
u-joint issue
i have been told by a garage that they have to replace my whole drive shaft because my u-joints are bad, i dont believe this is true anyone that has had bad u-joints and had them replaced can you give me a little help on telling them how to fix it or replace my u-joints without replacing the whole drive shaft would be greatly appreciated.
I noticed you live in Gladstone i live just north of 152 maybe you could give me a little advice? i have been told by a garage that they have to replace my whole drive shaft because my u-joints are bad, i dont believe this is true anyone that has had bad u-joints and had them replaced can you give me a little help on telling them how to fix it or replace my u-joints without replacing the whole drive shaft would be greatly appreciated.
Well, you don't need to replace the whole driveshaft.
But if you could scrounge up the money, the Ford Racing aluminum driveshaft is a very worthy replacement.
Silky smooth compared to the stock driveshaft, well worth the money.
I always use a angle grinder with a cutoff wheel and carefully cut the legs off the u joint then just bang the 4 caps out.. Never had any trouble with this method. Or you could cut them out with a torch the same way..
The stock joint caps are usually injected with some sort of plastic to keep them in place, so you will need heat to get them off. And if you watch while heating the ear you can see the plastic bleed out so you know its ready to be beat out with a hammer and socket. You will only need to heat one ear to bleed it then smack the opposite cap to force it out.
If you've got the type with injected plastic you DEFINATELY need to heat it. I had an old pickup with the caps held in with injected plastic and didn't know it. Beat hell out of it with a socket and a BFH to get it out. Well, I wound up bending the ear of the yoke just enough to vibrate the truck like crazy. what I had to do was put an indicator on the d.s. with the rear jacked up and roll it thru to mark the high side. I then tweaked the ears on the yoke back straight and it ran smooth.
If you have a vise that's large enough and some sockets you can use that as a press for disassebly and assembly. works quite well.
good luck.
Like this...
