  • 2005 - 2009 Specific Tech
Any Upper Control Arm write ups?
  • Thread starter Thread starter V8JamesGT
  • Start date Start date Sep 10, 2007
V8JamesGT
218
Sep 10, 2007
  • Sep 10, 2007
I just got my ajustable BMR UCA and it didnt come with any directions for installing it. I did a search for a UCA write up install and didnt find one. Mainly I would like to know how to set the pinion angle correctly. My car is not lowered. thanks
V8JamesGT
218
Sep 14, 2007
  • Sep 14, 2007
I'm installing tommarrow, so some help would be greatly appreciated.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Sep 14, 2007
  • Sep 14, 2007
i am not sure of the magic number to set the angle to, but here is a CAR CRAFT article about it. this is only the basics. http://www.carcraft.com/howto/91758/
here is another good link. this is not specific to our cars, but will give you a good idea. http://www.baselinesuspensions.com/info/pinionangle.htm
for the BMR arm, you loosen the jamb nuts, rotate the adjustment nut with a wrench, check/adjust the angle, and then tighten the jamb nuts. easy as cake. you will need a few specialty tools though.
bigcat
May 1, 2005
3,015
7200 feet
Sep 14, 2007
  • Sep 14, 2007
lol, when all else fails, i found this on the BMR site:
http://www.bmrfabrication.com/INSTALL/UCM001.pdf
why didnt i look there to begin with?
V8JamesGT
218
Sep 17, 2007
  • Sep 17, 2007
thanks bigcat! So are you going to upgrade your UCA anytime soon? After I get it installed and go back to the track I'll let everyone know how it helped...
White05GT
66
  • Sep 17, 2007
Please do. Also, if you could provide us with input on how much noise/vibrations/harshness increased (if any), it would be appreciated.
Casey4s
147
Woodbridge, VA
Sep 17, 2007
  • Sep 17, 2007
I installed a BMR Upper Control Arm two years ago. (10 K miles) It is the one that is adjustable with the Spherical Bearing. It works fine but it is now noisy as is the usual case with sphirical bearing suspension components. Make absolute sure you torq everything to specs (130 ft lb) and check it periodicaly. The install is pretty straight forward, but lowering the fuel tank is a pain in the A$$.
Good luck with the install...
retfr8flyr
154
  • Sep 17, 2007
If your car isn’t lowered you shouldn’t have to worry about the pinion angle. Just measure the center to center distance on the stock arm and adjust the new arm to the same length before you install it.
Earl
V8JamesGT
218
Sep 18, 2007
  • Sep 18, 2007
do I need to lower the fuel tank if I'm not replacing the UCA mount?
bigcat
May 1, 2005
3,015
7200 feet
Sep 24, 2007
#10
  • Sep 24, 2007
  • #10
sorry, been on vacation for a while. this is the first time i have logged on to SN since my last reply. i am waiting for an adjustable upper from J&M.
V8JamesGT
218
Sep 26, 2007
#11
  • Sep 26, 2007
  • #11
Well, apparently YOU DO have to lower the fuel tank in order to install the UCA. With the BMR UCA write up it made it sound like you only needed to lower the fuel tank if you were installing the UCA Mount. Then, me and my friend had trouble getting the stock bolts off. Ford use a lot of lock tight on them. We ended up running out of time so we kept the stock UCA on and rescheduled to put the BMR UCA on sunday.
Casey4s
147
Woodbridge, VA
Sep 26, 2007
#12
  • Sep 26, 2007
  • #12
Loweriing that fuel tank was a major pain in the Arse to do. I did mine in my garage with no helper, off of jack stands. Actually putting it back on was the tougher part for me, but you have a helper so that should make a big difference. Make sure you get your pinion angle correct when finishing.
Good luck and work safely...
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Suspension Rear pinion angle
  • JD1964
  • Apr 30, 2025
Fox 5.0 Mustang Tech May 5, 2025
JD1964
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 12:05 PM
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Saturday at 7:48 PM
AlexM556
A
