The problem is startup current draw. For ~0.01seconds, the fan/motor will draw over 100amps. For cheap, or under rated, relays that causes pitting on the relay contacts. That pitting gets worse over time.
I know very well how SUPER MEGA *****ED someone is if/when their electric fan dies! That's one reason why I'll never ever use a POS aftermarket electric fan again - EVER! Hey, if someone has a POS car/engine that they don't give a rat's *** if it blows up, or if they get stranded in the middle of nowhere, then fine - go ahead and buy/use a POS aftermarket fan!
Uhm, the point?An OEM fan is good, But, it's still only as good as it's weakest link. In the case of a 30amp relay on a Taurus fan, that's the weak link. IMHO, it's not worth it.
NAPA sells an 80 amp continuous duty relay for ~$60.
NAPA ECH ST85 Relay
Product Line: Echlin Ignition
Part Number: ECH ST85
Price: 58.49
For 12 Volt Systems, Continuous Duty, 80 Amp, Insulated Base, Flat Bracket, Coil 16-21 Ohms Same As ST80 Except Has Copper Contacts; NAPA Echlin Products Meet Or Exceed Original Equipment Specifications. All Products Are Top-Of-The-Line Quality, & 100% Tested & Inspected In An Environment That Is IS09000 Compliant.
if you spent 60 on a relay, why wouldnt you just spend 70+ for a good fan controller?
i use to have mine on a toggle, now i have a dcc controller. so nice to just sit there and watch it take care of the cooling. i still have a manual switch wired in should i ever need it/for the track too.
I ordered a DCC controller 3 weeks ago. However I have no idea when it is going to show up. This is just a temporary solution. The relay is off my old 89 that had a Taurus fan years ago.
ahh gotcha. i hear you on the controller. thats why i waited to buy one new that i didnt have to wait for
NAPA ECH ST85 Relay
Price: 58.49
As long as you have a good relay for the high-speed, and plan on changing out the low-speed relay, then I'd say try the 30amp relay now.That's the exact relay I have now. Obviously I can only operate one speed at a time with it though.
You don't really need 2-speed fan operation. I mean it's slick and all. But a good controller and high speed is all you really need
