anyone else have this much trouble?
LXstang5.0
22
Ohio
ok so ive been tryin to put on my FR aluminum driveshaft on for about a week now and i still cant get it. ive pretty much got it cover in grease and what not and it wont go. i feel really dumb cuz i no how easy it is but is there any tips, tricks?
What won't go in? The slip yoke to the transmission? Are you sure it's the right one? Does it have the same splines as the transmission? Will it not go in at all, or just halfway?
Where did you get the driveshaft from? Are you sure its for a fox/or fox SN car? The yokes may be different. Just look at or count the splines...i know its a tough task...but that will surely give you the answer.
I would stop trying to install it and start taking some measurements to make sure you have the right part. Installing a DS is as simple as sex...just put it in.
ok so i counted the splines on each of the driveshafts (stock and aftermarket alum) where the yoke goes into the transmission. and both have the same # of splines......27 or 28 (i forget which one lol) but i counted it like 20 times to make sure and they are the same. but the splines seem closer together on the yoke on the aftermarket driveshaft one than the stock. also the driveshaftseemed a liitle longer too. so am i really that bad at getting it in or do i have the wrong driveshaft?
