  • SN95 4.6L Mustang Tech
Anyone else with oil consumption?
  • Thread starter Thread starter 40th GT
  • Start date Start date Nov 24, 2005
40th GT
916
Lawrenceville, GA
Nov 24, 2005
  • Nov 24, 2005
My GT just used up about 1/2 quart in 700 miles. This doesn't seem normal for an engine with 9000 miles..What I'm guilty of though, is I let a mechanic overfill the crank by 1 quart because he was going by the dipstick and not the owner's manual. That was when I wasn't aware of Ford's recall on their dipsticks. Since that incident I've always changed my own oil.
Could that have blown a main seal? When I looked at the base of my Triax, there was engine oil all over it which scares me. What are some other signs of a blown main seal? Shouldn't the clutch be slipping too? (Mine grabs hard)
98blackmagic
386
wouldnt you like to know
Nov 24, 2005
  • Nov 24, 2005
With oil all over the shifter, I would be nervous too. Usually if the main seal is leaking if you park in the same spot every night you should have a small spot on your driveway. I'm not sure about the clutch slippage.
DogVomit
192
Tampa, FL
Nov 24, 2005
  • Nov 24, 2005
Try putting a flattened out cardboard box under your car as soon as you get home and check it in the morning for oil.
I can't imagine how oil could make it into the shifter assembly. Wouldn't it dump out of the bell housing? If it's in the shifter assembly, your gear lube/tranny fluid has oil in it
Bottom line is... That is IRREGULAR oil consumption. Take it to the dealer once you locate the leak.
DogVomit
192
Tampa, FL
Nov 24, 2005
  • Nov 24, 2005
Bottom line is... That is IRREGULAR oil consumption. Take it to the dealer once you locate the leak and never mention anything to do with overfilling or anything!
RandyStinchcomb
1,159
Randallstown, Md
Nov 25, 2005
  • Nov 25, 2005
asper FoMoCo: a quart of oil used between 800 and 1000 miles is considered normal.
ponysarepretty
578
  • Nov 25, 2005
WTF... 1 quart per 800 miles?
stng
182
  • Nov 25, 2005
What kind of oil are you using? I have been running mobil 1 synthetic 5w-30 and I loose at least one quarts per oil change, sometimes as much as 1 1/2 quarts. I was then told by a mechanic that synthetics have lower burn temps and that was why I was burning so much oil. I always thought synthetics had higher burn temps but I have decided to just switch back to either castrol gtx or maybe the synthetic blend with my next oil change and see what happens...
DogVomit
192
Tampa, FL
Nov 25, 2005
  • Nov 25, 2005
I've got 48,000 miles on my GT. Never added oil between oil changes. I change my oil every 3-5k. Now every 3 since the S/C install and use only synthetic.
But I never add oil.
On a typical Friday, I drive 350 miles to spend the weekend with my fiance and drive 350 home, back to Tampa. That's 700 miles. My oil is still good for 2300 miles till my change, and I won't even bother checking it.
03MGT
199
  • Nov 25, 2005
How maney quarts did he put? Just curious??
bridge4d
11
Houston, TX
Nov 25, 2005
#10
  • Nov 25, 2005
  • #10
Synthetics are more stable due to their purity, thus they don't crack as easy and don't have as many light distillates (short chain hydrocarbons) that get consumed at lower temps. However, they are not as viscous and can get past gaskets and piston rings easier than dino oils. My Expedition was consuming about 4-5 quarts in-between changes. I switched to synthetic and now it only losses about a quart every 5K miles.
Fast02
239
#11
  • Nov 25, 2005
  • #11
I've read on this site that you should wait 10k miles before switching to synthetic so that the rings can wear properly first.
Oil on the base of the Triax...hmm...are you sure its not just dirty Tranny fluid? Have you checked the base bolts of the shifter did you use forma gasket or a supplied gasket on the shifter? If it is motor oil make sure you put your original shifter on before bringing it to them.
Take it to the dealer just to be on the safe side and get it documented at least.
DogVomit
192
Tampa, FL
Nov 25, 2005
#12
  • Nov 25, 2005
  • #12
Good point. I'd also not mention the oil looking substance in the shifter assembly to them. That HAS to be that color because of a broken down form-a-gasket goo. Oil can't make it there and you shouldn't even mention that. But the oil consumption is bell housing forward. So they probably wouldn't even check into the gearbox.
40th GT
916
Lawrenceville, GA
Nov 25, 2005
#13
  • Nov 25, 2005
  • #13
7 quarts total. Which is 1 quart more than what my manual says.
40th GT
916
Lawrenceville, GA
Nov 25, 2005
#14
  • Nov 25, 2005
  • #14
Well I was thinking it was motor oil because it had that yellowish brown color of motor oil. Tranny fluid is dark red right? And yes, I've always had a shifter gasket installed.
According to Mobil1, the 10k mile rule is a myth. High-end cars come factory-filled with Mobil1 and I seriously doubt that their manufacturers run their engines to what's equivalent to 10k miles on dino oil.
40th GT
916
Lawrenceville, GA
Nov 25, 2005
#15
  • Nov 25, 2005
  • #15
:Word:
Can someone double check this please?
40th GT
916
Lawrenceville, GA
Nov 25, 2005
#16
  • Nov 25, 2005
  • #16
Mobil1 5w-20 here. I'm using the weight that the owner's manual suggests, and I always have been.
Synthetics definitely have a higher flash point than conventionals, so no, that's not the main cause of my oil consumption.
ponysarepretty
578
#17
  • Nov 25, 2005
  • #17
My opinion on the whole synthetic vs dino is that companies who sell more dino oil than they do synthetic will say synthetic will do all kinds of stuff. If they have some synthetic products, they will probably make a recommendation that you use it for some time then switch. If they are all synthetic they will probably tell you to start with synthetic and end with it.
Believe who you will.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Engine New Oil Leak Help.
  • Slo5Oh89
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 19, 2025
Slo5Oh89
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
4.6 question for those in the know....
  • LILCBRA
  • Aug 30, 2024
2K
2005 - 2014 S-197 Mustang -General/Talk- Sep 4, 2024
Adieu
