Anyone ever paint their master cylinder
I usually put a clear on just to keep it from rusting but every time you pull the cap off needs to be a surgically clean procedure as brake fluid will eat the paint right off. There are fluid resistant coatings; check them out... it seems I remember seeing some at Eastwood.
just go to your local home depot or Lowe's and get some Red Devil (or any brand really) Appliance Epoxy paint, brake fluid won't eat through the epoxy nearly as bad. VHT also makes some epoxy paints as well that you can order from summit or jegs if you can't find them locally.
Here it is
Painted:
