nonglossjason said:farbeyonddriven, arnt you to old to skate?
Im still in my 20's bitch!!!!!!nonglossjason said:farbeyonddriven, arnt you to old to skate?
Im still in my 20's bitch!!!!!!z2o_what said:i havn't skated since '99 or '00 but i here is some of the brands i used.
decks i used: 4 alien workshops, 2 santa cruzs, 3 blinds(had alot of concave which made them best for fliptricks) , 1 stereo, 5 birhouses, 1 foundation (this was my favorite)... "slicks" were the strongest, but i dont think they make slick decks any more.
trucks: destructo (favorite, but the king pins are weak),
destoyer (too heavy but very strong),
grind king (light, and grind down fast),
indy( too heavy and the axles slip alot)
bearings : pigs (suck)
lucky (suck)
black quickies (good low cost bearing)
bones swiss (very good)
fdk: (with nylon covers would last forever)
china bones: (decent)
wheels: spitfire, bones
hardware: shorties
griptape: black magic
FarBeyondDriven said:Thanks for all the info.... this is what i have so far... whatcha think?
ALIEN WORKSHOP KIRCHART VERITAS SM DECK 7.50 width $114.99
ROYAL EVOLUTION TRUCKS -- SILVER -- 7.75 $0.00
SPITFIRE HEAD BURST WHEELS -- MULTI -- 55mm $0.00
custom parts selected RED BONES BEARINGS $2.00
PIG SKIN GRIP TAPE $0.00
CHECKS RISERS $0.00
FLIP HKD HARDWARE
z2o_what said:i go with a smaller wheel, like 50mm or 52mm
i would get shock pads instead of risers, unless they are low risers
you should be fine with those bearings if they are the same as china bones
AW makes a strong, comfortable deck, but personally i would go with a little wider deck (7.75)
i never had royal trucks, but i would get them the same width as the deck... but it not like .25 is got to make any difference.![]()
FarBeyondDriven said:ok, ill look at that truck and board width issue tomorrow (im not planning on ordering this stuff till tomorrow anyways)
the only reason i looked at the bigger wheel, was becasue it said it was for a person over 150 pounds, and the smaller wheels benefitted people 150 pounds and under.
the risers are 1/8"... is that too thick? and whats the difference between shock pads and risers?
im ordering this stuff through CCS, and they dont have a ton of options, so im just trying to get the most decent stuff i can. so if you get bored, hop over to www.ccs.com build a board so i can see what you would come up with... if you dont mind![]()
z2o_what said:alright, this i what i came up with using their complete packages... i would have picked a few different things but its cheaper to shop by brand, than mix-match your own parts.
after giving it a little thought you would be better off using the risers as long as they are rubber to help prevent pressure cracks, and give a softer ride.
i have never heard about a larger wheel for a larger rider. i weighed around 180-190lbs. when i skated and always rode 50s or 52s.
the reason said to look into a smaller truck size was because i dont like to have my wheels stick out on the side of the board, but it doesnt effect you riding.
ALIEN WORKSHOP SALAZAR BELIEVE DECK -- MULTI -- 7.88 width $109.99
DESTRUCTO MID TRUCKS -- BLACK/GOLD -- 7.75 $5.00
SPITFIRE OR GLORY LAST STAND WHEELS -- MULTI -- 52mm $0.00
DESTRUCTO COMPLETE PARTS PACKAGE DESTRUCTO SPEED METAL BEARINGS $0.00
JESSUP GRIP TAPE $0.00
DESTRUCTO RISER PADS $0.00
DESTRUCTO HARDWARE $0.00
Assembly Charge: $0.00
Total: $114.99
