Anyone here using the tall trick flow valve covers?
gnx547
283
Anyone here using the tall trick flow valve covers? I was wondering hows the clearance on the pass side with the throttle linkage? Does the tall valve cover hit it? Any modifications you have to do to use these valve covers?
I cant help ya much since im using them and running a carb, but i have had to call TFS for some stuff like that before, and they are pretty damn knowledgeable with stuff like that. Might be worth a shot..
1-330-630-1555
With a 1" spacer my TFS tall VCs clear my linkage bracket but with a little assistance from my dremel. I elongated the holes in the bracket a little to allow it to slide up just a bit so it will clear the VCs. I have a Trackheat intake and as I said earlier a 1" spacer. Without the spacer I do not see anyway to make it work with serious surgery to the bracket.
