anyone know how ignitions work?
YEs because red/blue is hot in start. red/green is hot in run. Normally the tfi module provides the power to the coil when the key is in the start position. If you do not have a TFI module, you will not have this function, and thus you have your problem.
What you need to do, is connect your coil to both red/blue and red/green wires.
-HOWEVER-
You also need to put a diode on each wire so that power from one isn't going to blackflow into the other circuit. Otherwise turning the key to ON will be like turning it to START and ON at the same time.
So attaching r/b and r/g to the small red wire will do the trick as long as i have a diode on both of them? how does a diode work?
thanks for all the help, how old are you guys? im 20
A diode is a one-way check valve for electrical current. It only allows power to flow one way. It goes in-line with the wire. Wire it to allow current to flow to the coil, but not from it. I'm 25 :nice:
sounds good, i just got it started!! but i did it with no power in start, just the red wire attached to my fuel pump toggle switch. So now can i just attach a new wire from the white/pink with a diode on just that?
The fuel pump should be relay controlled.
attachment.php
EDIT: Relay & socket part numbers
Relay Radio Shack Catalog #: 275-226
Relay socket Catalog #: 55017871
Igniton wiring...
The red/green wire is hot in both crank and run modes, since it used to activate the EEC power relay.
It goes to the small red wire on the MSD box. The wire wire fro the MSD goes to the distributor (green/yellow
on the original wiring) The big read wire goes to a 20 amp inline fuse that connects to the battery side
of the starter solenoid. The big black wire goes to a bare metal ground on the body.
From the diagram...
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer,. actuator & sensor wiring
Fuse panel layout
Vacuum routing
By the way, I'm 61 - old enough to be your grandfather... :D
well i got it to work by attaching the small red to the red/lt grn under the ignition switch, and by attaching the white/pink wire in the engine bay (which somehow was only hot during run) to the red wire as well, and it doesnt start when i turn it to run, but starts right up like a normal car. yessss. Only problem now is the brand new battery is dead.
well i got it to work by attaching the small red to the red/lt grn under the ignition switch, and by attaching the white/pink wire in the engine bay (which somehow was only hot during run) to the red wire as well, and it doesnt start when i turn it to run, but starts right up like a normal car. yessss.Only problem now is the brand new battery is dead.
glad to hear you got her running man. think i was confusing more than helping :rlaugh: , but i tried. sounds like a big wiring fiasco you got there. a friend of mine had the same problems with his 89 when he went carbed, he ended up buying an hei dizzy so all he had was 1 wire to fiddle with.
so the alternator only has the black and orange that turns into green and the white and black? i think the alternator is good because it stays running when i detach the battery, but its not charging the battery. is that green one the one that charges it?
There are two green wires in the alternator circuit.
One is the dark green fuse link wire that connects the alternator power feed to
the battery side of starter solenoid. If the fuse link blows, the alternator will not
provide power or charge the battery.
The other light green wire is the one that signals the voltage regulator to turn on
because the ignition switch is on and the engine is supposed to be running. If it
doesn't have 12 volts with the ignition switch in the run position, the alternator
will not charge. This same light green wire also operates the battery signal light
on the instrument panel.
what do u mean by the alt. power feed? where is this fuse? and if it was that fuse that blew, wouldnt the car shut off when i detach the pos. side of the battery?
also, no 12v in run at the lt. grn wire means the alt. will not charge... [the battery?]
thanks
thanks?
:shrug: I guess I must be speaking GEEK or something. I never thought that my
explanation was that hard to understand....:shrug:
thanks
Unless you can think of something else on your car that can take a charge, yes, it's the battery.
The altrernator feeds power to your car. It uses a wire to do this. The power feed wire. It's the thicker wires that come off the alternator. Just before it reaches the battery side of the starter solenoid, it goes through a fuseable link. All a fuseable link is, is a thinner piece of wire than the rest of the wire it's connected to.
If your alternator is not putting out any power, yes your car will shut off when you remove the positive battery cable. However, even if the alternator is putting out only 9 volts the car will still run. So it's not really a test of a good or bad alternator.
