Anyone know which connections are which on the hydrobooster?
Derek 350i
10
Central IL
I am retrofitting a 99 Mustang hydroboost brake system into my project car, and I am not sure which connection is which. There are two large fittings and one small fitting. One large and one small fitting are beside each other and the other large fitting is by itself.
My guess would be that the solo large fitting would be the high pressure in from ps pump, the large fitting by the small one is the high pressure out to steering rack, and the small one is the bleed off fitting from the fluid that has been used by the booster. But again, these are guesses and since I am going to have to have lines made and this is a relatively important system, I really need to know for sure.
Also I am guessing the front brake outlet goes to the fronts and the rear to the rears, but would like to be sure.
TIA
