304billet said:$700. need to pull the heads and intake. about 8 hrs @ $85/hr. Most shops charge $70.
no need to pull the heads at all......304billet said:$700. need to pull the heads and intake. about 8 hrs @ $85/hr. Most shops charge $70.
legalize420gt95 said:no need to pull the heads
sickboystang said:Our shop rate is $45 per hour and I'm sure the Labor Time guide will call for around 7 hours R&R time plus parts, gaskets, fluids, etc. So that puts it about 400-425at my shop. And our labor rate up here is low on a national average.
Ocalafox said:Rick, with the afm tools you can leave the intake on correct? Should "all" cams, even Buddy or Ed's be degreed when installed?
vann
Rick 91GT said:That sounds about right to me...and I agree the HP to $$ increase will be very little. If you do want to swap cams try a Crane 2031 it works very well with a stock Cobra set-up and you will increase HP and TQ across the entire curve.
I don't pull the heads either I have a set of the AFM cam tools, they work very well.
Jesus dude, 45 bucks/hr. You guys work for peanuts.sickboystang said:Our shop rate is $45 per hour and I'm sure the Labor Time guide will call for around 7 hours R&R time plus parts, gaskets, fluids, etc. So that puts it about 400-425at my shop. And our labor rate up here is low on a national average.
