Anyone running 60# injectors with stock computer?
Trbofox
227
18
Erie,Pa.
Anyone have any experience with this. i am running a 85mm Abaco mass air meter and can get the car to idle with good air/fuel, but on start it floods, as it must be reading for 19# injectors. What is anyone compensating with?
I just finished a customers car, 76mm turbo with a stock 93 Cobra computer and I used a SCT chip to pull the fuel out down low and tune the car, only air meter I could get to run smooth was a Pro-M Pro-Tube, C&L and Abaco gave me issues...
There is a crank fuel table in the tune that (while in cranking mode) fires the injectors for a preset pulsewidth. Making your injectors 3 times larger than stock pretty much puts in 3 times as much fuel as stock. That would do it.
Also, changing airflow meter calibrations will have an effect on the overall fuel injected for sure, but it has no effect on injector characteristics. There's more to injector specs than just their static flow rate. Injector delay time, battery voltage compensation, breakpoint, and other things must be reprogrammed or the car will never idle right.
The larger the injector over stock size, the worse that problem will be. You should also know that as you reduce the airflow reading that the meter puts out, you also reduce the load the computer calculates. That increases spark timing, which could be dangerous or at least not ideal. You need a real tune.
