anyone running a pusher fan?
Jaym14
296
Long Island, N.Y.
I seem to be having some cooling issues that I'm trying to iron out...
I have a b-cool aluminum rad, stock water pump, taurus electric fan with the dcc controller. I'm considering throwing on a pusher fan. I'd install it offset from where the taurus fan is (the taurus fan is not centered because of water pump clearance issues).
I'm not overheating, but its hotter than I'd like to see. When I'm at speed the car does run cooler.. sitting in traffic it gets hot in a hurry. :mad:
I was looking at this fan to use as a pusher Summit SUM-G4904 - Summit® Electric Fans – SummitRacing.com.
What do you guys think?
pusher fan will actually hurt you, because the two fans will work against eachother. try running a higher amp feed to the fan, my 5.0 95' fan at 40amps would not cool right but i baught a 75 amp kit and now i have no problem
