Anyone running WITHOUT spring isolators?
i am running without a left rear isolator, back is drooping bout 1/2 inch as well as making alot of noise comparativly, and ride harshness has greatly increased in the rear... its not THAT bad, but annoying when only one is gone.
Torinalth
Well, the reason I started this thread was because I swapped out my suspension from my Bullitt. Bullitt suspension out, and this suspension in:
- Bilstein HDs all around
- H&R Race Springs
- Urethane spring isolators on all 4 corners
- Pro3i LCAs
- Steeda HD UCAs
- GRC Performance SFCs
Well, I was going to go with H&R SuperSports but got worried about the drop. I want to go with long tubes next and did NOT want any scraping issues.
The H&R Race springs provide less of a drop (an additional drop from the Bullitt springs of 1/2 inch.) I thought this would be perfect. Three other Bullitt owners ran these and liked their handling and slight drop.
After installing Race springs with the urethane isolators, my ride height has INCREASED over the stock Bullitt height! After waiting 2 weeks, my fronts are 1/8 inch higher and rears are a whole 1/2 inch higher.
What options should I consider:
1) Remove all isolators
2) Cut the current Race springs slightly & keep isolators
3) Get the SuperSports and sell the Race Springs (kind of a PITA & pricey)
All suggestions are much appreciated!
That's really to bad... overall that sounds like a sweet setup! I love my SuperSport springs, they are the perfect drop IMO. If you can sell the Race springs I would go that route. I definitely would not even consider cutting those springs, bad idea. And you could try and remove the isolators but still don't think you'd be happy.
