If you have a friend it makes it way easier. If you dont' you can still do it. I have changed many pumps by myself.. Just need a good jack and a flat board. Use the jack to lower it and raise it.
2 bolts holding the fuel tank.
3 holding in the fuel fill up area
and then pull the tank to the left so the fill up tube comes out of the tank.
becareful with the plugs that hook up to it. I say lower it half way then disconnect the plugs and then lower it the rest.......Its eaiser with almost no gas.....
