Anyone Use This Harbor Freight Engine Support Bar?
  • Thread starter Thread starter killer5.0
  • Start date Start date Jan 17, 2018
killer5.0
5 Year Member
Oct 8, 2009
725
83
59
Jan 17, 2018
  • Jan 17, 2018
Going to be replacing my k member...and my motor mounts as well as oil pan and timing cover gaskets while its out...
https://m.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html
Just looking to see if anyone has used this and quality/strength etc
BlakeusMaximus
Still got to try a little lube on my speedo head
5 Year Member
Jul 12, 2017
2,477
1,349
173
Jan 17, 2018
  • Jan 17, 2018
We use those in the body shop when we have to replace crossmembers/engine cradles. Not harbor freight brands though. I’m sure it would work out fine.
95BlueStallion
My assy trans to myself
5,129
3,100
214
Cedar Rapids, Iowa
Jan 17, 2018
  • Jan 17, 2018
No, but the first thing I would do is swap out the bolts holding the weight of the engine to some grade 8 bolts, and the chains to some thick heavy duty ones... You get what you pay for with hardware, and if my engine was hanging in the balance, Id be sure it remained hanging with a couple cheap upgrades.
Reactions: BlakeusMaximus
BlakeusMaximus
5 Year Member
Jul 12, 2017
2,477
1,349
173
Jan 17, 2018
  • Jan 17, 2018
Yeah those chains seem kinda weak.
BlakeusMaximus
5 Year Member
Jul 12, 2017
2,477
1,349
173
Jan 17, 2018
  • Jan 17, 2018
Most of the people’s reviews on it seem ok. Looks like it did the job.
67coupe
658
402
93
Huntsville, AL
Jan 17, 2018
  • Jan 17, 2018
Used it to replace a timing cover and oil pan gasket on a 93 GT. Worked fine. No issues.
View: https://m.youtube.com/watch?v=VY0-66RpOsA
eighty5fox
Mustang Master
Sep 29, 2016
286
303
83
mass
Jan 17, 2018
  • Jan 17, 2018
I used it to drop my k member to do my oil pan have no complaints about it. I did also get a bigger chain and wrap it around and bolt it to the head just to be in the safe side. Its nice and solid otherwise
Steel1
Mustang Master
Aug 18, 2017
1,419
639
143
Connecticut
Jan 18, 2018
  • Jan 18, 2018
My friend has one that we used to remove/replace engine in 2006 VW Passat, worked fine.
killer5.0
5 Year Member
Oct 8, 2009
725
83
59
Jan 18, 2018
  • Jan 18, 2018
Thanks for the replies...i will go with a thicker chain and grade 8 bolts...doesnt make sense not to for a few bucks...i have aluminum 11r heads...where should i hook the chains?
FoxMustangLvr
I love my Pimp
SN Certified Technician
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jan 18, 2018
#10
  • Jan 18, 2018
  • #10
I've used the accessory bolt locations on the heads when I've pulled my engine. Maybe you can do the same thing with this support bar?
Reactions: killer5.0
Nutty 5.o
612
185
93
SE PA
Jan 23, 2018
#11
  • Jan 23, 2018
  • #11
I used it on my 05 Focus to replace clutch and it worked fine. Not necessarily the best example for you, but I did use the chains they provided.
P
Hello, core supports for '86 vs '90-3, i need some answers if anyone knows
  • Pony Dr.Mike
  • Mar 14, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 15, 2026
95steedamustang
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Sunday at 6:09 PM
JD1964
D
Resolved Vortech hitting hood
  • Dchichizola
  • May 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2025
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
