Anyone Use This Harbor Freight Engine Support Bar?
We use those in the body shop when we have to replace crossmembers/engine cradles. Not harbor freight brands though. I’m sure it would work out fine.
No, but the first thing I would do is swap out the bolts holding the weight of the engine to some grade 8 bolts, and the chains to some thick heavy duty ones... You get what you pay for with hardware, and if my engine was hanging in the balance, Id be sure it remained hanging with a couple cheap upgrades.
Reactions: BlakeusMaximus
I used it to drop my k member to do my oil pan have no complaints about it. I did also get a bigger chain and wrap it around and bolt it to the head just to be in the safe side. Its nice and solid otherwise
Thanks for the replies...i will go with a thicker chain and grade 8 bolts...doesnt make sense not to for a few bucks...i have aluminum 11r heads...where should i hook the chains?
I've used the accessory bolt locations on the heads when I've pulled my engine. Maybe you can do the same thing with this support bar?
Reactions: killer5.0
