aod/aode which is better?
  • Thread starter Thread starter BK_CAULEY
  • Start date Start date Jan 7, 2007
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jan 7, 2007
  • Jan 7, 2007
which transmission is better. im thinking the aode is but want a better opinion i have had mustangs with the aode and they feel like they are much stouter and i have had shift kits put in them and they are cheaper than the one in my aod. i never had one rebuilt but have had shops tell me the aode cost more to rebuild than an aod and if i want to swap in an aode in place of my aod what all would i need or is this not neccesary or not a good idea? thanks guys.
Nopantz
234
NJ/US Merchant Marine Academy
Jan 7, 2007
  • Jan 7, 2007
AODE is newer and is stronger. I believe there was a write up in Modified Mustangs in the January 07 issue, you might want to check that out. Also for all your automatic questions head over to clickclickracing.com . Its the best source for Ford Automatic Questions.
superhuaman
907
Harrisburg, PA
Jan 7, 2007
  • Jan 7, 2007
It is easier to put a "shift kit" in an AODE because it is done electronically, with a chip or box. An AODE will be more expensive and stronger, yes, and you can tune shift points and such, but you will need a stand-alone transmission computer for a Fox ($400-$600). Or you can use an SN95 ecu and wiring harness...cheaper, but more work.
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Jan 7, 2007
  • Jan 7, 2007
Upping the fluid pressure with a chip or box on an aode is not as effective as a real shift kit.
Either trans is fine, just put a real shift kit in either one.
I know, i have a shift kit in my explorer which is an aode. And we had an aod in our 90 vert years ago.
superhuaman
907
Harrisburg, PA
Jan 7, 2007
  • Jan 7, 2007
What does a "real shift kit" do different from just changing the programming of the AODE module?
89streetbeast
365
horton,ks
Jan 7, 2007
  • Jan 7, 2007
the j-mod type of shift kit is whats suggested for those AODE trannys. tccoa's website has a bunch of info on how to do it the right way. theres a couple guys on that site that sell the whole valvebody setup for your type of shift/application. last time i remember they were around 350-400 bucks. the transgo shift kits are junk. had one in my 94tbird. worked fine for awhile then the tranny went tips up. wished i woulda went with a jmod
89streetbeast
365
horton,ks
Jan 7, 2007
  • Jan 7, 2007
heres a link for the diy shift kit mod for aode's http://www.tccoa.com/articles/tranny/shiftybusiness.html
imho by the time you get done buying a tranny, having it built for your specs , doing the proper shift kit and getting a stand alone harness for it, you could buy a very nice built AOD that will handle quite alot. not saying the aode's are junk but its just not worth the hassle unless you like doin that sort of stuff and have alot of free time and money on your hands
HISSIN50
34
129
Jan 7, 2007
  • Jan 7, 2007
I don't get why the question even came up. Unless you like the electronically controller trannies, there's no point. That said, there are a couple of members here running a stand-alone controller if desiring their thoughts.
If swapping, why not go for a manual trans? Or go with a stout AOD build like everyone said. I think Mansonozz had a decent thread on the Corral not long ago which touched upon a lot of good stuff for an AOD build. He's real savvy and dose his homework so touching base with him (if you decide to go that route) might be a good idea.
Random thoughts.
Good luck.
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Jan 7, 2007
  • Jan 7, 2007
A real shift kit, basically is just the drilling out of fluid passage holes in the valve body. Relieves pressure that's already there.
A shift improver, that is not mechanical, Ups the line pressure forcing more fluid through the same size holes.
superhuaman
907
Harrisburg, PA
Jan 7, 2007
#10
  • Jan 7, 2007
  • #10
Ahh, I see. One is reversible and the other is not (at least, not easily).
A
Drivetrain 91 AOD linkage at transmission
  • alchemist1
  • Sep 29, 2025
Fox 5.0 Mustang Tech Sep 29, 2025
JD1964
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2026
DuluthFoxbody
D
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
