- May 7, 2006
- 74
- 0
- 0
hey guys... i need some advice/help on what to do.
My problem im hitting the rev limiter in third gear at the track before i cross the line!!
I have an AOD with a true 3200 stall and 4:10 rear gears...
Are any of you guys with 4:10's having similar problems????
Is there any mod you can do/buy to shift into O/D at WOT???
Will going with a lower stall increase the top end MPH???
i need help!!! i would rather not swap the rear gears to 3:73's but if thats the only way to get more MPH out of it, i guess i will have to.
thanks in advance!
thanks in advance!
R U using street tires? A taller tire will do it. I didnt see any major mods in your sig. Are you running the stock cam? Stock intake?
