AOD HELP
  • Thread starter Thread starter nonglossjason
  • Start date Start date Mar 13, 2006
nonglossjason
I did not have intercourse with a sheep.
Jan 27, 2006
138
20
39
Mar 13, 2006
  • Mar 13, 2006
Ok thanks guy for the help in advance but i have a question to ask. The other day i got in my car to back out of a parking space and put it into reverse but it didnt go. I shifted back into park than to reverse again and still didnt go. I pushed on the gas a little bit and it chirped the tires and then worked. In the past couple days it has done this to me twice but not everytime. I checked the tranny fluid and all is well but dont know what it could be. The guy i bought it off of said the tranny was rebuilt about 10 thousand miles ago. Any responses greatly appreciated
RYC CUKR
1,437
Orlando
Mar 13, 2006
  • Mar 13, 2006
If you have checked the fluid and it looks good next thing that I would look at is the TV cable and make sure that it is adjusted properly. If you do a search I believe that there are a couple of threads regarding the TV cable adjustment.
I would probably also change the fluid and filter just for the heck of it.
nonglossjason
Jan 27, 2006
138
20
39
Mar 14, 2006
  • Mar 14, 2006
ok thanks i will check that any other suggestions
M
macx
228
SE Missouri near Cape Girardeau
Mar 14, 2006
  • Mar 14, 2006
That can be caused by a number of things, but often
is caused by sticky valves in the valve body.
They're prone to wear in certain spots with higher miles.
I've even totally disassembled them, cleaned well, lubed
and reassembled and they STILL can stick. Last go round
I had to buy a $100 reman from a rebuilder.
Not a bad idea to change fluid, but before you do, you
might want to use a trans flush product. Just make
sure it's thin, NOT thick or it'll gum up the valve body.
(Don't ask me how I found THAT out!)
I've had good luck with some stuff that comes in a blue
quart can, can't remember the name. seems to be
pretty commonly available.
For some more info & possibilities, go to the Sonnax website.
They sell lots of small internal valve body parts for AODs etc,
and they have a list of common problems and cures that
sometimes can be of help.
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
Drivetrain AOD is very intermittent
  • 87fbmustang
  • Mar 20, 2025
Fox 5.0 Mustang Tech Mar 20, 2025
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
