AOD Linkage
  • Thread starter Thread starter Tims90LX
  • Start date Start date May 5, 2012
Tims90LX
Wisconsin
May 5, 2012
  • May 5, 2012
My problem is that when shifting the car I can't shift it all the way to 1st. With the stock shifter it felt like I just couldn't pull the shifter down far enough. Also took it to a trans shop and he said the cable looks like it needs to be replaced. So..replaced the cable a few weeks ago still didn't help. Put in a B&M Hammer shifter yesterday yaay prob fixed..wrong. Still won't shift down to first. The only thing i can think of is the linkage going into the trans but when I manually shift it under the car it doesn't feel sloppy and i have no problem putting it in first.
95Vert383AOD
1,133
34
69
New Bedford, MA
May 5, 2012
  • May 5, 2012
Welcome to my world. What kind of AOD Trans do you have? Is it stock for that vehicle? I have an AOD from a 1990 Lincoln mark 7 Manual valve body. With a B&M hammer shifter in my 95 mustang. If i adjust the linkage to 1st perfectly it wont go all the way into park. And if i adjust it to to Park it wont go all the way to first.
One solution i hear is that for different years ford/mercury/ lincoln actually changed the length of the shifter lever on the transmission itself. Theres a universal aftermarket lever with multiple holes. I bought one and plan to install.
Either way i'm subscribing to see if anything good comes out of this.
Tims90LX
Wisconsin
May 5, 2012
  • May 5, 2012
Sounds like the same exact problem as me. I need to get it on a lift with someone inside so I can see exactly what the linkage is doing when its shifting. I'll let you know if I figure something out.
Tims90LX
Wisconsin
May 5, 2012
  • May 5, 2012
And my AOD is original as far as I know
95Vert383AOD
1,133
34
69
New Bedford, MA
May 5, 2012
  • May 5, 2012
Well let me know....Ive never had so many problems with a shifter lever/ linkage ever. I was looking at tossing in a Lokar unit. It bolts to the top of the tranny or the trans tunnel OE style and uses either a cable or a solid rod to shift.
A
Drivetrain 91 AOD linkage at transmission
  • alchemist1
  • Sep 29, 2025
Fox 5.0 Mustang Tech Sep 29, 2025
JD1964
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
