AOD n00b need some help
  • Thread starter Thread starter Camman
  • Start date Start date Jan 4, 2006
C
Camman
1,055
Las Vegas, NV
Jan 4, 2006
  • Jan 4, 2006
So I finally got to drive the car for more than 5 minutes today. Now, I used to work as an auto guy at a local pontiac dealership... in my n00b experience it feels to me like the torque converter lock up solenoid isnt functioning properly. Heres why:
It doesn';t have any problem idling(so no tcc problem here)
It has a 2800 stall converter. Every once in a while when I mash the throttle it will actually jump up to 2800 rpm and feel like a bat out of hell. Other times it feels like the tranny is already locked up and the dudes on the bicycles go flying past me until I can hit 2800 rpm(which takes a good 12 seconds). If I put the fuxer in 1st gear manual it will work without a hitch, but as soon as it hits second gear it immedietally shifts into third, even tho I only have it in d... Help. It has a transgo shift kit... what does this sound like to you guys?
Cars Mods:
89 gt vert
trickflow streat hieat kit
24lbers pro-m mass
bbk shorties, bbk catted h
The car is equiped with a 150 shot... I have never used it(the bottle is full tho)Dunno if nitrous will kill these trannys or not(dude says he only hit it 3 times)
3.73(these are going into the other manual equiped 89 i have)
Stock suspension(Yes folks a moron built this car)
2800 stall(100 miles)
transgo shift kit(100 miles)
recently(2000 miles) rebuilt aod
Others probably, just cant think. Thanks for any help you can administer...
superhuaman
907
Harrisburg, PA
Jan 4, 2006
  • Jan 4, 2006
Well the shift kit should only make it shift harder. It sounds to me like you have an early-shifting problem. This is the stock line pressure governor working against the 3:73 gears. It can also be caused by a misadjusted throttle valve cable.
Modular2v
3,222
23
99
oklahoma
Jan 4, 2006
  • Jan 4, 2006
i swear aods are gay!!!!!! tv cables gesh!
C
Camman
1,055
Las Vegas, NV
Jan 4, 2006
  • Jan 4, 2006
darn... I am in no condition to lift the car to check line pressure... so if this is the problem the tranny could be getting fried from the high pressure?
C
Camman
1,055
Las Vegas, NV
Jan 4, 2006
  • Jan 4, 2006
hah I agree, unfortunetally I am stuck with one for a while
superhuaman
907
Harrisburg, PA
Jan 4, 2006
  • Jan 4, 2006
Low line pressure is worse than high line pressure.
C
Camman
1,055
Las Vegas, NV
Jan 4, 2006
  • Jan 4, 2006
am I right in saying it is high? I just figured since it was shifting early
superhuaman
907
Harrisburg, PA
Jan 4, 2006
  • Jan 4, 2006
I thought high line pressure caused late shifting... because if you have your foot into it, the line pressure should be higher, to shift later and firmer, because of the power being applied.
It sounds like either you have low line pressure, or that the governor is fighting the rear end gears. I've heard of that happening. The only way you can fix that is with a valve body or valve body mods.
I don't know if you know how the AOD works, but the throttle valve cable is connected to your right foot and controls the line pressure (runs off the pump). The governor also makes its own pressure off the output shaft. The valve body compares these pressures and decides when to shift.
So basically, with numerically higher rear end gears, the trans is seeing higher than normal output shaft speed, and decides to upshift, albeit early.
willys1
1,004
New Jersey
Jan 4, 2006
  • Jan 4, 2006
what about when you have the gas pedal nailed? what does it shift at? Do you have the correct speedometer gear in?
superhuaman
907
Harrisburg, PA
Jan 4, 2006
#10
  • Jan 4, 2006
  • #10
The speedo gear won't affect how the transmission operates.
C
Camman
1,055
Las Vegas, NV
Jan 4, 2006
#11
  • Jan 4, 2006
  • #11
Actually I was under the impression there was no governor in the aod, thanks for that. I assume the transgo shift kit had valve body mods in it? What else would it be? So I guess I gotta take it somehwere to get the line pressure adjusted... how much should that run me? I dont really want to wait until I can do it for fear of the tranny... although it has probably been wrong for 2000 miles or so, and the dude put in a higher stall thinking it would fix it(im totally guessing here).
When the throttle is nailed in drive it shifts somehwere around 5000 rpm(within 200 rpm variation). If I nail it with the selector in 1 it will hold until I shift out, I shifted at 6000(stock tach) today and it immedietaly shifted into 3rd when I upshifted manually(it stayed in second for maybe 200 rpm). The tranny is shifting hard, and it has excellent pressure(tested in reverse) judged by me. The fluid doesnt smell burnt, and is still red and translucent. However, I did notice the fluid is aerated(sp?)(full of air bubbles), not sure if that is normal for aod's or not.
superhuaman
907
Harrisburg, PA
Jan 4, 2006
#12
  • Jan 4, 2006
  • #12
From the TransGo website (about the AOD shift kit):
Short, firm shifts with "class". Manually hold 1st, 2nd, and 3rd to any RPM. Manually downshift to any gear at any speed. Holds 4th at high speed/throttle.
So it doesn't sound like there are any governor modifications.
I believe it the Ford dealer will charge between 1 and 2 flat-rate hours to check and adjust the TV pressure, since as you know, it requires the use of a lift and a pressure gauge. Most independent garages won't touch this, other than tranny shops.
I think the fluid would be aerated if you drove it somewhat hard before you looked.
It sounds like it is working ok with regard to the engagement and everything else, except for the quick 2-3 shift of course.
M
macx
228
SE Missouri near Cape Girardeau
Jan 5, 2006
#13
  • Jan 5, 2006
  • #13
AOD's are pretty close ratio 1-2-3, and shift pretty
quickly from 2 to 3 even with stock gears.
When you go deeper gears, it shifts even quicker.
Stock, the Mustang AOD shifts out of 2nd at about
4750, so if you held it in 1st to above that, that's
why it immediately shifted into 3rd.
I don't know much about the tci kit, but with the
Baumann kit that can be adjusted some, basically
they up the line pressure a little.
For instructions on how to check the tv pressure,
look on the tci website.
I just got a decent 100 psi oil pressure gauge with
a wide sweep so I can get a fairly accurate reading.
I took a short chunk of 7/16 bolt and used a hacksaw
to cut a short notch in it part way lengthwise to slip
over the inner cable - with the notch cut, it about
equals the .400" gauge block.
If you want to rev higher, the only way I know to
be able to hold 2nd gear is to get a Lentech valve body.
Oh, BTW, there is no torque converter solenoid in an AOD. Lockup is done with the direct clutch pack. There's a skinny little inner/3rd input shaft that hooks
from a hub inside the front of the converter directly
into the direct/3rd clutch pack. So you pretty much
go into lockup when you shift into 3rd if you have anything but a Lentech valve body.
HISSIN50
34
129
Jan 5, 2006
#14
  • Jan 5, 2006
  • #14
Camman, have you hit the TCCOA site/forum? Jerry's articles alone can shed a lot of light. Because the birdies seem to have been more likely to come with autos (than stangs), there is a LOT of good info. Here are some articles.
Good luck bud.
C
Camman
1,055
Las Vegas, NV
Jan 14, 2006
#15
  • Jan 14, 2006
  • #15
whoa I totally missed your reply jt. and macx, thought the thread was dead. Thanks for the advice, I am gonna go check out those articles now. Macx thanks for the insight, never did any reading on the aod. I do know it is pretty widely thought of as a pain to work on tho. I guess again I am thrown back into needing a lentech... thought I lost that problem with the 65. Thanks guys
G
HELP!! A4LD in 93 Mustang slips badly in reverse when warm
  • goofyfoot53
  • Apr 25, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Sep 10, 2024
89ripper
AOD Shifter adjustment
  • Trogdor
  • Jun 4, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2023
alutwon
N
Engine 1994 Mustang GT AODE puzzling issues
  • noah5slow
  • Oct 22, 2022
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Oct 29, 2022
noah5slow
N
Fox AOD Overdrive to 3rd Hard Downshift
  • Motorsport71
  • Mar 18, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2021
junkyardwarrior
J
Drivetrain Need knowledgeable AOD help
  • 92LX50
  • Jan 31, 2020
Fox 5.0 Mustang Tech Feb 1, 2020
JD1964
