AOD problem anyone with experience?
pdiddy1
14
ohio
Is that normal for the outer shaft to move that much?
View: https://www.youtube.com/watch?v=WRB2UUmYNbQ
I have AOD 89 casting with vibration problem in 3rd gear around 1800rpms (32mph or more), it goes away instantly when transmission goes in OD(4th).
What i tried so far:
  • Balancing driveshaft
  • new TC
  • New tailshaft bushing
  • I have correct flexplate 28oz (its 289 engine)
  • Sponsors(?)
LX Dave
152
72
38
45
I've seen them with just a little bit of play but never that much. Looks like it's time to tear into it.
Stang_1973
556
San Antonio, Tx.
How strong is that 289? those AODs a pretty vulnerable in stock form. I broke a shaft just trying to pass somebody once. Im assuming you are still lockup TC?
the guy who fixed my AOD way back when once told me that the shaft can even just twist at the ends.
these guys were very helpful as well when i built my AOD. found everything i needed. If you haveto rebuild it, might as well make is stronger.
pdiddy1
14
ohio
It is stock 289 so not much power, the small inner shaft looks good. The AOD works good, beside the vibrations that i mentioned, with 3.70 rear-end I hit 70mph at 2200RPMs....I had c4 before and it was not fun with speeds over 50mph.
What upgrades would be good if i need to open the AOD?
- Reverse sun shell (94-95)?
- Reverse drum from any 4R70W?
- mechanical diode from 98+ 4R70W transmisson?
- intermediate pressure plate from 98+ 4R70W transmission? ...thanks
Stang_1973
556
San Antonio, Tx.
well i was convinced Non lock up was the way to go and i believe we did single piece input shaft, which right now is probably still overkill for me but I was told by several people that was the only surefire way to make it near break proof. the only other lock up that can take high HP is electronically controlled. thats what i was told anyway. but i upgraded my valvebody to a lentech. it increases oil pressure throughout so you dont have have worry about burning out a gear and you can drive the car like a manual safely. as for the other stuff it was all direct replacement stuff, i dont remember taking stuff from other models. just remember getting better quality rebuild kit, better OD band, larger servo, this was like 10+ years ago. I just remember my Tranny guy at that time telling me what i needed, then spoke to PATC and put together a "packge" of stuff. With the valve body and stuff we did get, i remember my tranny guy saying it could handle upwards if 500 HP. my main mechanic said in his opinon it could take probably closer to 600-650. Im no where neat that but im working that way.
but if your not looking to make high HP anytime soon, at least probabl;y not over 300, and if your gunna have to rebuild anyway, its not much more for a better rebuild kit. I remember the guys over at PATC were very knowledgeable and i beleive they even have an in house project car that is a "happy balance" for a tough reliable AOD in a classic mustang. its a lock up hardned input shaft setup i believe and it has a 289 or 302. id call them up and see what they think.
sorry if i wasnt much help in that regard.
Mr.Kelley
40
32
28
56
San Diego Ca
It looks like the pump to input shaft bushing is toast. No there should not be that much play. Have you run the car up to speed on a lift to find the vibration. Hate to go through all that trouble with the tranny and still have a vibration when its back together. By the time you get all the 4R70W guts to beef up the AOD you might as well just get a 4R70W and buy a controller.
pdiddy1
14
ohio
Thanks Mr.Kelley....is that the bushing in the attached picture(red circle)? Stator(Rear) bushing i think part number is "76037".... so there is no vibrations when I'm in "P" or "N" and rev it up to 4000rpms, and no vibrations in "OD". I get vibrations just in 3rd at around 32mph or higher. So far i have not tested it on a lift.
Mr.Kelley
40
32
28
56
San Diego Ca
That would be 036 & 037 There are probably other bad things going on if it's vibrating. Your looking at tearing it apart and replacing some hard parts. I was in the same boat. I had just rebuilt my stock AOD adjusted the TV cable had good pressures and took a test drive. Everything worked great had nice firm shifts when I expected them. When I got back to the yard I had no reverse (I think I got the front 1 way clutch in backwards) I pulled it back out and the pan was full of silver flake. My converter is eating itself. My thoughts were to get the 4R70W guts to beef mine up, get a new converter and rebuild it again. That route depending on the converter was going to runaround $600 with me doing all the work. I traded my old C4 for a 4R70W from a wrecked 70k mile 94 Mustang. The controller and tranny harness is a little over $600 but now I can tune the shifts on the fly. I still have my AOD in the car If your near San Diego and can wait a little while it's yours for the asking.
pdiddy1
14
ohio
For now ill follow you, Mr.Kelley, and try to save the AOD by replacing the stator bushing 037. I was looking on the parts listing and it seems to me that the 036 is for AODE and 4r70w, but I might be wrong. The order was placed so I hope it will be here this week and I can mess with transmission this weekend. I was thinking about 4r70w but the controller price scared me away. Thanks for the help...ill post the progress.
Mr.Kelley
40
32
28
56
San Diego Ca
Here's the full pages. Looking at the video I'd bet the damage goes deeper than a couple of bushings. It looks like there is also a lot of end play. The shaft your wiggling in the video is the forward drum in the second picture, it houses the reverse clutch, and the overdrive band clamps on the outer surface of it. that tha
Mr.Kelley
40
32
28
56
San Diego Ca
Continued. So the forward drum spins in all forward gears except OD. If that play was your only problem you'd have the vibration in 1-3 and maybe smooth out in OD.
pdiddy1
14
ohio
Thank you for the pictures....I have been draining the oil since yesterday so after work ill try to pull the AOD out and start the disassembly.
markinms
47
65
Columbus MS
Are you happy with the Lentech Valve Body? Shift improvements? Reliability? I'm waiting for mine to arrive any day now.
Mark
Reactions: Stang_1973
pdiddy1
14
ohio
Mr.Kelly, AOD is out and slowly taking it apart...the stator bushing did not look bad. Here is first issue, or maybe it is normal:
That sound is not present while driving the car.
Stang_1973
556
San Antonio, Tx.
Mark
I frekin love it!!!!! I have the one where you can switch off the O/D. i drive it like that on the small streets and turn it back on while on the highway. when theres alot of traffic stop and go i leave it in D. but when you have space i like to drive it manual. and for the "fun" ill hold my shifts to 5K if i dont start spinning too bad. its alot of fun! never had any issues with the transmission since that and it was like 10 yrs ago.
Mr.Kelley
40
32
28
56
San Diego Ca
That is one of two 1 way clutches, AKA overrunning clutch or Diode, Does the tranny make that noise when the car is running? If so which gears what, what speed. I'm getting to the edges of my experience and as a disclaimer I most admit I'm not an expert just have some recent experience with rebuilding an AOD.
markinms
47
65
Columbus MS
Love the enthusiasm! Mine arrived yesterday and will install this weekend. Excited!
Mark
pdiddy1
14
ohio
I have the AOD transmission apart...Anyone has recommendation for clutches for street application?
Thread starter Similar threads Forum Replies Date
montegoman351 Fresh AOD...have PROBLEMS, CAN ANYONE HELP!?! Fox 5.0 Mustang Tech 3
EXTRPR50 AODE, Transgo kit problem, anyone? 1994 - 1995 Specific Tech 9
L aode to t5 pedal problems 1994 - 1995 Specific Tech 1
Stang5919 TCI 3500 problems 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
5 Aod Problems After Rebuild Fox 5.0 Mustang Tech 10
9 :94 Aode Shifting Problems 1994 - 1995 Specific Tech 2
N Aod Problem? Fox 5.0 Mustang Tech 6
BKM48198 Aod Trans Problem In Reverse Only Fox 5.0 Mustang Tech 0
S Drivetrain New To Stangs, Need Help Diagnosing Aod Problem! 1994 - 1995 Specific Tech 10
xMalignancy 92 Mustang AOD Trans problems Fox 5.0 Mustang Tech 1
G New AOD, having problems shifting, TV pressure issue.. Fox 5.0 Mustang Tech 32
BKM48198 AOD trans linkage/shifting problem Fox 5.0 Mustang Tech 1
R AODE to T5: Starter Not Engaging Problem 1994 - 1995 Specific Tech 7
Z AOD problem Fox 5.0 Mustang Tech 8
smitty1991 Monster Transmission AOD major problems Fox 5.0 Mustang Tech 2
joshwfl Weird AOD Problems Fox 5.0 Mustang Tech 7
L ODD AOD TV CABLE PROBLEM Fox 5.0 Mustang Tech 0
smitty1991 1991 GT AOD reverse problem Fox 5.0 Mustang Tech 1
C 85 GT AOD/CFI Fuel Gauge Problem Fox 5.0 Mustang Tech 2
8 AOD Transmission Problems Fox 5.0 Mustang Tech 2
stanglover0526 aod problems Fox 5.0 Mustang Tech 0
9 95 GT AOD problem Fox 5.0 Mustang Tech 2
L aod problem! help please Fox 5.0 Mustang Tech 6
R aod problem, lock up??? Fox 5.0 Mustang Tech 1
superstroke17 Tranny problem-aod Fox 5.0 Mustang Tech 9
6SpeedLX Weird AOD starting problem Fox 5.0 Mustang Tech 5
K AOD Problems... I am clueless.... Fox 5.0 Mustang Tech 3
H AOD tranny Problems(lucas) Fox 5.0 Mustang Tech 5
M AOD problem?? SN95 4.6L Mustang Tech 11
EDGE Motorsport AOD problems in 88GT Fox 5.0 Mustang Tech 1
F AOD problems Fox 5.0 Mustang Tech 0
B could this be the cause of my aod problems? Fox 5.0 Mustang Tech 14
8 AOD problems Fox 5.0 Mustang Tech 15
dcurtis AOD Problem Fox 5.0 Mustang Tech 5
R AOD shifting problem and swap question Classic Mustang Specific Tech 1
dbiser aode problem? 1994 - 1995 Specific Tech 14
D Installing TransGo Shift Kit in AOD - problems Fox 5.0 Mustang Tech 3
M Aod problem maybe? Fox 5.0 Mustang Tech 6
9 AOD Problem Fox 5.0 Mustang Tech 1
B 93 aod problems, help please! Fox 5.0 Mustang Tech 3
bobbyd aod shift problems Fox 5.0 Mustang Tech 3
B Aod problem 2.3L (N/A & Turbo) Tech 1
95StallionGT 95 AODE problems 1994 - 1995 Specific Tech 1
V AODE + gear change = what problems? 1994 - 1995 Specific Tech 12
68torinogt AOD problems!! Fox 5.0 Mustang Tech 13
R AOD rebuild problems, help if you can!!! Fox 5.0 Mustang Tech 3
GT_green_GT 95 AODE shift problems 1994 - 1995 Specific Tech 3
S big problem removing computer! AODE to T5 swap guys... 1994 - 1995 Specific Tech 3
J AOD tranny problems after gear install Fox 5.0 Mustang Tech 17
L AOD Problem Fox 5.0 Mustang Tech 2
