AOD Problems
  • Thread starter Thread starter 90' LX 5.0
  • Start date Start date Aug 15, 2006
9
90' LX 5.0
59
  • Aug 15, 2006
Ok... so I have a 1991 Mustang LX 5.0 with an AOD tranny.
When I place the shifter in drive, the engine will rev freely until it hits about 2,000 rpms... then it will either slam into gear or slip into gear. Once its in gear it shifts fine...
Except for coming from OD to Drive. In order for it to engage drive after being in OD I have have to bring the RPM's up.
Any Ideas?
89-notchback
35
Phoenixville PA
Aug 15, 2006
  • Aug 15, 2006
Not trying to be an ass, but did you check the fluid level first when it's running and up to temp?, that will make a tranny do that.
9
90' LX 5.0
59
  • Aug 15, 2006
ya tranny fluid is full and red... if anything its a little over full... but not by much... smells fine too
N
NFGTragedy
155
Rochester, NY
Aug 15, 2006
  • Aug 15, 2006
Maybe the linkage needs to be tightened where it meets the tranny? It might be loose and not fully pulling into drive but once you rev it up the vibrations might make it pop in? Just an idea to check and it would be a free fix Other then that, I have no idea.
9
90' LX 5.0
59
  • Aug 16, 2006
Ok.. so now it wont go into drive at all.. Reverse still works... but 1 D or OD and the engine just revs freely like its in neutral... There are no noises at all, its exactly like being in neutral.
Vinnietbird
584
  • Aug 16, 2006
I can't say it's your problem,but I had a similiar occurrance with mine a few months ago.I pulled the valvebody,and on a VERY clean work area (surgically clean !!!),I took the valves out cleaned them and reinstalled them ONE AT A TIME (so they don't get mixed up),paying very close attention how the springs and pieces are installed.After a thorough cleaning,the car shifted like new.Been great and taking abuse ever since.Perhaps that helps.Good luck.
billison
I like tinted tail
2,607
1,094
184
stl
Aug 16, 2006
  • Aug 16, 2006
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Aug 16, 2006
  • Aug 16, 2006
My buck is doing the same right now, but it won't go into any gear. it just revs. I am just gonna junk that heap, its on its 3rd tranny
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
