What is a good aftermarket shift for an auto, Don't really want to butcher up the stock console. Want somethig that will just bolt rite in. Some pictures would be great to give me an idea how they look.
B&M makes a nice one if i recall correctly. I think it is a waste of money though unless you are using some special type for a drag only. For a street car i'd put the money somewhere else.
B&M Hammer shifter is about the only for an AOD that is a direct bolt in I know of. I also looked for one when installing an AOD in my car. But I ended up using an B&M Pro stick( like the Hurst 1/4 stick), since my tranny had the electric OD delete. You can use the Hurst 1/4 or B&M Pro and get the plate for it so it can mate with and AOD. But if you have a C4 then you can use just about any shifter you like. Also when installing the B&M, I used the mounting plate from Holcomb Motorsports that installs the shifter in the stock location.
Here is the Hammer:
Here is My B&M with a Holcomb mounting kit cover with a 5 speed boot.....
