AOD Torque Converters
  • Thread starter Thread starter 885.0conv
  • Start date Start date Jan 22, 2008
1 of 2 Next Last
885.0conv
238
Phoenix, Az
Jan 22, 2008
  • Jan 22, 2008
I am going to change my torque converter and was wondering if a lock up one or non lock up one would be better. Car is a stock 5.0 but will have a h/c/i change. Thanks for the help as always.
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
West Coast Best Coast
Jan 22, 2008
  • Jan 22, 2008
A lock up will run cooler. Get the lock up youll be happier.
F
Fox8950
247
Jan 22, 2008
  • Jan 22, 2008
No lockup = no overdrive so you will basically turn it into a 3 speed and since the TC never locks up its ALWAYS slipping which as GTO said makes the non lockup run hotter. Now on the other hand if your ever planning on really feeding an AOD some power you pretty much have to get rid of the lockup feature or you will twist off intermediate shafts like nobodys business. From the combo setup you have it sounds similar to mine and I've had nothing but fun with it and love the highway manners with overdrive (even with 4.10 gears) the one thing I would suggest is to reinforce your AODs major weakpoint and while you are in there changing the TC buy a hardened input shaft and replace that since it will be right there.
U
UnderdogGN
74
  • Jan 22, 2008
You still have overdrive with a non lockup converter. Although with a non lock there will never be a 1:1 ratio, which means you will turn higher RPM's than a lockup converter because its always slipping. If you want the absolute best times at the track and dont care too much about highway driving, get a non lock. If you like to cruise alot and wont see alot of track time, get a lockup.
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Jan 22, 2008
  • Jan 22, 2008
And IMO theres only 2 converters to choose from for a stock/mild 5.0
Precision Industries is the best with Edge converters in a real close 2nd.
885.0conv
238
Phoenix, Az
Jan 22, 2008
  • Jan 22, 2008
Thanks, I guess I will go with a lock up since I will be doing a lot of cruising and just some track time. I want to get about 300-350hp do you think the hardened input shaft would handle that.
885.0conv
238
Phoenix, Az
Jan 22, 2008
  • Jan 22, 2008
Now on the other hand if your ever planning on really feeding an AOD some power you pretty much have to get rid of the lockup feature.
Fox8950 what do you mean by "some power"?
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Jan 22, 2008
  • Jan 22, 2008
500 + HP
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Jan 22, 2008
  • Jan 22, 2008
Call the companys up. They have a tech line and will tell you which one to get, just tell them what you have.
N
NEG1071
10
#10
  • Jan 23, 2008
  • #10
do you self a favor and talk with silverfox at clickclickracing.com also visit dirtydogperformance.com and speak with Alan about his converters.
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Jan 23, 2008
#11
  • Jan 23, 2008
  • #11
www.converter.com
The Stallion is for 5.0's
F
Fox8950
247
Jan 23, 2008
#12
  • Jan 23, 2008
  • #12
How does an AOD still have overdrive when you take out the input shaft that runs the OD? .. In order to switch to a non lockup coverter you have to pull that shaft out which IS your 4th gear. Not trying to flame just wondered if I missed something, have rebuilt a couple of these (and they both actually worked yay!) like to find out all I can.
** 3rd gear is 1:1 4th gear is .068:1 right?
** And yes on the hardened input shaft it will handle 350 no prob, mine has held up nicely even banging into gears with the shift kit at just over 5k rpm
U
UnderdogGN
74
#13
  • Jan 24, 2008
  • #13
Im not exactly sure how to explain correctly but you can use a 2 piece or a 1 piece input shaft with a non lock. What did you mean when you said "In order to switch to a non lockup coverter you have to pull that shaft out which IS your 4th gear." ?
Did you mean take out the whole shaft, or switch to a 1 piece?
I dont think overdrive has anything to do with the input shafts, but im not positive. I just know you can run a non lock and you will still have overdrive.
Id also like to find out these answers, so anyone who can help us out, please chime in!
rsw007
469
Lexington,SC
Jan 24, 2008
#14
  • Jan 24, 2008
  • #14
www.edgeracingconverters.com
adre is great to deal with.
as far as converters go dont go anything less than a tight 3000stall.
keep lock up if you plan on mostly street driving.
i run a lock-up 3000stall edge converter. and can 60ft in the high 1.6's on motor and low 1.4's on the spray.
F
Fox8950
247
Jan 24, 2008
#15
  • Jan 24, 2008
  • #15
The intermediate/direct input shaft IS the lockup feature .. it splines directly into the back housing of the TC and is ALWAYS 1:1 with the motor .. this is the weak link because its a 3/4 diameter shaft and is eliminated with non lockup converters because when you bang into 3rd gear at WOT and the direct clutch engages to achieve the 3rd gear 1:1 ratio it then proceeds to torque the end right off the shaft. At least this has been my understanding just from the rebuilds and studying I have done to try and figure this damn trans out someone plz correct me if I'm wrong.
**The AOD has a 3 piece input shaft from the factory, the only one I'm talking about removing is the smallest diameter shaft that pulls right out without any trans. disassembly
rsw007
469
Lexington,SC
Jan 24, 2008
#16
  • Jan 24, 2008
  • #16
my stock pencil shaft lasted one weak with the new tranny. then i installed a hardened one, and its been in there for 5 years with no problems even with nitrous.
rsw007
469
Lexington,SC
Jan 24, 2008
#17
  • Jan 24, 2008
  • #17
rsw007 said:
my stock pencil shaft lasted one week with the new tranny. then i installed a hardened one, and its been in there for 5 years with no problems even with nitrous.
P
Paisu
#18
  • Jan 24, 2008
  • #18
Which brand was the new one?
F
Fox8950
247
Jan 24, 2008
#19
  • Jan 24, 2008
  • #19
Pretty sure theres only a couple companies that actually make the hardened input shafts just lot of people carry them. I thinkin the 300M alloy shafts you can't go wrong with, haven't had much experience with the 4340 alloy shafts but have "heard" they are the weaker ones.
U
UnderdogGN
74
#20
  • Jan 24, 2008
  • #20
rsw007- What suspension/tire set up do you have to cut those 60 fts? Im having trouble getting my car to hook.
fox8950- that makes sence, but, i just know that you can have a non lock converter with a one piece input shaft, and still have overdrive. I know that because thats what i have in my car.
1 of 2 Next Last
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
Drivetrain Witness marks on Torque Converter
  • Mcmahst
  • Mar 19, 2025
Fox 5.0 Mustang Tech Mar 21, 2025
85GTStangGuy
