AOD trans fluid spraying out of radiator?!?!
  • Thread starter Thread starter jaymac
  • Start date Start date Mar 20, 2007
1 of 2 Next Last
jaymac
995
Northern Mass
Mar 20, 2007
  • Mar 20, 2007
I thought it was originally a busted tranny cooler, so I swapped that out, and now it's still all wet arounf the radiator after driving home. So, I'm assuming that the trans cooler tank in the radiator is craked/broken somewhere, right? That's the only other palce it could be spraying from, I believe. Has anyone ever experienced this??
If this is the case, on to my next question, What is the best DIRECT FIT rad? FMS, Fluidyne? I want a zero-headache, zero-extra-parts-needed-halfway-into-the-project installation. Can anybody give me some help from experience? Thanks,
Jeremy
Aryan15
236
CA
Mar 20, 2007
  • Mar 20, 2007
Where is the trans fluid coming out of?
jaymac
995
Northern Mass
Mar 20, 2007
  • Mar 20, 2007
I can't pinpoint it. After I wiped it dry and drove home, the whole area around the front bumper, drivers headlight, top of the rad. by the filler neck, even the passneger side tank was wet the other night. So I think it;s just cracked thru and leaking, but the coolant is not leaking... weird...
Aryan15
236
CA
Mar 20, 2007
  • Mar 20, 2007
On my car, the cooler in the radiator consists of a tube in the driver's side tank which transfers heat to the coolant. I've had the quick disconnect fittings leak but I don't see how the tank could leak fluid but not coolant. Check the fittings and your seperate trans cooler, I think you said something about a trans cooler.
jaymac
995
Northern Mass
Mar 20, 2007
  • Mar 20, 2007
yeah, I already replaced the coler and the hoses, etc., It's not leaking from the fittings on the radiator... I don't get it, but it's spraying violently out of somewhere...
HISSIN50
34
129
Mar 20, 2007
  • Mar 20, 2007
J - make sure the PS cooler isnt what is spraying ATF all around............... It's in front of the radiator.
I think the HD 3 core rad's can be had with a heat exchanger (like stock). Otherwise, a stock replacement would probably work, or stepping up to a Fluidyne (I believe they have plug-n-play units with heat exchangers) would work.
Good luck bud.
T
time only
461
Miami,FL
Mar 21, 2007
  • Mar 21, 2007
Just wondering if those are not power steering fluids.... Check hoses and the PS cooler in front of the radiator.
jaymac
995
Northern Mass
Mar 21, 2007
  • Mar 21, 2007
no, I'm 99% sure it's the tranny fluid itself from the rad. Unless the fluid I put in the tranny feeds the PS cooler too. Every day, the tranny fluid drops low again, leading me to believe that it's gotta be the rad. leaking. from somewhere...
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Mar 21, 2007
  • Mar 21, 2007
If the trans cooler in the radiator is what is bad, replace it right away. An Escort at work had that problem. Well, the lady brought it in for a slipping transmission. First thing I did was check the trans stick, and it was filled all the way up....but with antifreeze/water. The fluid was pink. Her trans could not be saved after a new radiator/trans flush. We replaced the transmissions and all lines the next day. I would get the fixed before this happens to you.
As far as a replacement, Autozone has a 3 core copper replacement. That would be a good one if you are on a budget. Otherwise an aluminum Steeda or Fluidine would be great. Check radiator shops too....the one they made for my Cobra was only 300 bucks, and it was custom.
jaymac
995
Northern Mass
Mar 21, 2007
#10
  • Mar 21, 2007
  • #10
so I'm not crazy? It could be a problem with the tranny cooler in the rad., even if the rad. itself is not leaking coolant?
Also, does my 88 even have a PS cooler? I've been all around that area lately and haven't noticed one. I guess I'll check again...
SVT32VDOHC
3,501
28
119
Motor City
Mar 21, 2007
#11
  • Mar 21, 2007
  • #11
It COULD be the problem, but you want to pin-point it to be sure. Yes, the 88 has a P.S. cooler. It starts near the bottom of the rad support on the driver side. It runs through the rad support, up to the top of the rad support then loops down back through the bottom of the rad support, back to the rack and pinion. There are no fins on it, it is just a steel peice of tubing. That could be leaking too, but P.S. fluid is a neutral color, or dirty, depending how old, and obviously tranny fluid is red, so you will have to be sure of the fluid. Can you see it leaking while idling lookin under the hood?
HISSIN50
34
129
Mar 21, 2007
#12
  • Mar 21, 2007
  • #12
Our PS systems use Type F ATF.
jaymac
995
Northern Mass
Mar 21, 2007
#13
  • Mar 21, 2007
  • #13
it's not the PS cooler. That fluid is maintaining just fine. The tranny on the other hand, contin ues to look fluid. i could see nothing leaking/spraying under the hood when idling, but it's coming out of somewehre HARD. When I park and open the hood, it's dripping from the front corner of the bottom lip of the hood, by the headlight. it's wet all behind the headlight, and wet BIG TIME by the bottom drivers side of the rad. tank. However, it's not wet around the tranny lione fittings, just on the tank and ALL The surrounding areas. it's gotta be the tank...gotta be...
Any way to bypass the tank and see if that's the problem?
HISSIN50
34
129
Mar 21, 2007
#14
  • Mar 21, 2007
  • #14
Do you have an aux trans cooler? You can bypass the stock heat exchanger and just run the aux cooler for a day or however long you need diagnose this.
Something I might try:
It seems to me that the heat exchanger uses 1/4" NPT fittings. You might be able to *very carefully* plug one end and apply light air pressure to the other end (pressurizing the exchanger slightly). You might be able to hear hissing or see remaining fluid pushed out when you do this. It's kind of the same idea as pressurizing a cooling system.
It was already probably answered, but if your coolant is changing colors, that's another sign.
Good luck.
tbovee
129
Fredericksburg Va
Mar 21, 2007
#15
  • Mar 21, 2007
  • #15
Try checking the lines from the trans to the radiator. They go from the pass side front of the motor to the center and then across and up to the drivers side to the cooler. maybe they have rusted and the fan or air flow across the radiator is blowing the fluid around?
T
time only
461
Miami,FL
Mar 21, 2007
#16
  • Mar 21, 2007
  • #16
Wet behind the headlight on driver side. No aftermarket tranny cooler hook up.
There is only 2 fitting going in and out of the factory rad for the build in tranny cooler and it is on the other side of the rad. There is only the PS cooler in front of the rad. I would put my hand on it and shine a light at the whole lenght of that PS cooler,it might be cracked . And turn the steering wheel to put some load on that pump.
jaymac
995
Northern Mass
Mar 22, 2007
#17
  • Mar 22, 2007
  • #17
No, I do have an aftermarket cooler. First I thought it was that, so i replaced it. not the problem.
Nope, they're on the driver's side.
The power steering is not leaking. The fluid level is constant. The ADO fluid is draining on a daily basis and needs to be refilled. it is AOD fluid. No question.
I ordered a rad. from Autozone and will hope to put it in sometime between Tomorrow and Friday. I will prob replace all the hoses going from the hard lines and hope the hard lines themselves aren't rusted through, causing the problem.
it won't hurt to replace the rad. anyway...
$uperstang
476
Detroit, MI
Mar 22, 2007
#18
  • Mar 22, 2007
  • #18
Yeah the tranny lines are on the driver side. If it is leaking that hard you should be able to find the leak, very strange???
jaymac
995
Northern Mass
Mar 22, 2007
#19
  • Mar 22, 2007
  • #19
thats the thing - it's not leaking - it's SPRAYING!! There's fluid soaking EVERYTHING under the hood, so I can't possibly find the origin...It's crazy. I'm beginning to suspect one of the rubber hoses could be a culprit also, so I got new hose to replace the old ones when I throw in the new Rad. Either way i'm replacing the rad. The new one is bigger and most importantly, new, and that's important where I have underdrives, an AOD, and no electric fan. Overheating can become an issue in summer traffic.
So, I guess we'll see!!
HISSIN50
34
129
Mar 22, 2007
#20
  • Mar 22, 2007
  • #20
If you clean everything up, can you look in under the hood (while wearing eye protection and other safety stuff - seriously) and try to see the source of the spray while your significant other cranks the engine? It's probably a small hole to spray that wickedly.
Good luck.
1 of 2 Next Last
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Engine Utilize trans cooler on manual car?
  • hemi_fan
  • Jan 2, 2021
Fox 5.0 Mustang Tech Jan 3, 2021
hemi_fan
Could not pass this up .. guess the AOD is out
  • mikestang63
  • Jun 1, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2024
FastDriver
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
M90 root blower how to info
  • 1987LXragtop
  • Jan 7, 2011
  • SN95 V6 Mustang Tech
8K
SN95 V6 Mustang Tech Jan 7, 2011
1987LXragtop
