aod tv linkage
I'm droppin an aod into a carbed 84 that was converted to 5.0. i'm having trouble finding people who have used the aod with a carb without burning it up. any suggestions/advise? what kind of brackets/linkages/adapters do I need? I have the stock tv cable if its reuseable. thanks for any input.
can anyone show a pic of the lokar hooked up to trans. was the trans shaft lever pointed down? and did the cable do a loop downwards and come from the rear, was there a boss on the trans to mount it?
did the original spedo cable work? hopefully there is some slack up under the dash that i can pull, cause it dont get it
The stock spedo cable fits just fine. There is a bracket on the fram that you need to loosen in order to move it around.
The lokar kit comes with some instructions. If I recall, it comes with its own bracket for the TV linkage.
