aod wide open
  • Thread starter Thread starter ultra50
  • Start date Start date Jul 12, 2007
U
ultra50
Cottonwood, MN
Jul 12, 2007
  • Jul 12, 2007
anybody able to get their aod to shift in drive in the 6000 rpm range?
really don't want to go to a manual valvebody .
thank's for any ideas.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jul 12, 2007
  • Jul 12, 2007
it wont. see http://clickclickracing.com/ for a fix to that. as long as you are holding the throttle wide open the detent cable is gonna keep it kicked down to 3rd gear.
5.0fox
410
buckley/enumclaw wa
Jul 12, 2007
  • Jul 12, 2007
Are you talking about doing a neutral drop or getting it to shift into overdrive?
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Jul 12, 2007
  • Jul 12, 2007
BAD IDEA!!! trust me dont do it...
ninety15.0
1,336
  • Jul 12, 2007
Are you asking if it will shift into any gear at 6k rpm or just shift into drive or OD?! I dont know much about autos but i know the AOD will not shift into OD at WOT....as mentioned above? please clarify what your asking and why you want this to happen?
RYC CUKR
1,437
Orlando
Jul 12, 2007
  • Jul 12, 2007
WOT + OD band is a bad bad bad idea. Especially if you have the stock OD servo in the car. The OD band in the AOD is a weak link. It is really to narrow and it is also handicapped by the stock "B" servo. These two problems lead to OD band failure eventually. Some people can get by doing it for a while and for others it only takes a few WOT bursts to smoke the OD band. Ask me how I know . My 93 is currently and AOD without the OD.
$uperstang
476
Detroit, MI
Jul 13, 2007
  • Jul 13, 2007
He is asking how to make his AOD shift later at like 6grand rather then 5 grand. If you play with the TV cable it may be possible.
RYC CUKR
1,437
Orlando
Jul 13, 2007
  • Jul 13, 2007
Well I was way off on that one. Hopefully this will help make up for it.
Follow the link, scroll down to #9 and it will tell you how to up the WOT shift point.
http://www.clickclickracing.com/forums/showthread.php?t=2444
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
