Unless someone has started to make a new adapter (haven't seen the summit one) you need the Lokar or Total Performance kit.
The problem is that the geometry of the AOD is such that if you simply hook the TV cable to the carb the TV valve bottoms before the carb reaches WOT. Bottoming the TV valve is bad for it and your wallet. If you adjust it so that it doesn't bottom you end up with low TV pressure at part throttle, which is also bad for the AOD and your wallet. Be aware you will need a good oil pressure guage and a couple of adapters to tap into the line pressure on the AOD. You set the TV cable with the oil pressure guage. It is a PITA.
When I did my Crown Vic I was able to find a hole in the carbs linkage that would work (thus I didn't have to weld the lever that lokar will provide to the carb.) but it would never have worked without the longer lever that they provide for the tranny.
I used a Holley, the kit should work with any 4V, but I wouldn't count on finding a hole that worked without welding on anything but a Holley.
