  • 1994 - 1995 Specific Tech
AODE and codes! Help
  • Thread starter Thread starter Synned
  • Start date Start date Aug 26, 2005
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Aug 26, 2005
  • Aug 26, 2005
536 (O,R,M) Brake On Off open or shorted to ground
632 (R) E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
Get these both while running, as well as 653, which doesn't exist so I read it wrong but its right next to the codes about torque converters.
What do they mean?
95BlackTan50
116
  • Aug 26, 2005
When you run the test did you step on the brake at any time? I think that the test is expecting you to do that. Same may be true with the E4OD code. With my AODE if you don't cycle the OD switch during the test, you get a code. I don't think the instructions tell you when to push the button but I just cycled it a few times and it didn't set the code.
Good luck.
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
ECU help!
  • starkiller1134
  • Aug 16, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Need help with wiring any advice
  • K1tha1
  • Sep 20, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2024
K1tha1
