  • 1994 - 1995 Specific Tech
AODE Rpm's with 4.10's
  • Thread starter Thread starter davins130
  • Start date Start date Oct 31, 2004
davins130
424
  • Oct 31, 2004
i bought my 4.10 gears at a ford expo last summer. i brought it to a shop to have them put in my car, and i was expecting a crazy change. it felt different, but not as much as i thought. On the highway at 70mph im at 2400 rpm with 4.10's with overdrive on(its an auto) before i cruised at 2000 rpm at 70mph. i guy i know said that there is no way that there are 4.10's in there. Who else has an auto w/ 4.10's, if you do what rpms are you at going 70? I cant really open up the diff. and count the teeth to check, so this is next best.
Mrgreen94gt
SIMMA DA NA!!!
448
West TN
Oct 31, 2004
  • Oct 31, 2004
With stock 17" tires, 245/45-17, it would be at 2504 rpm at 70mph.
With soemthing like 255/45-17, it would be at 2470 rpm at 70mph.
There's also the matter of how your speedometer is recalibrated for the gears. With a different speedo gear, it will be off by a little. However, with a correctly calibrated Speedcal, which is what I use, it will be as accurate as it can possibly get.
scarless
175
  • Nov 1, 2004
Your previous gears of 3:27, 2000 rpm, at 70 mph puts you with stock 245/45 x 17" tires. Using that, you aren't going 70 mph, but only 66.75 mph. 3:90 gears would give you 2400 rpm at 70 mph, or more likely is that you didn't install a speed calibrator and your speedometer is off. At 70 mph you should be turning 2516 rpm with 4:10's. FYI, a speed calibrator is the only way to fully correct this for an auto trans. Switching to the 21 tooth gear will make it closer, but it will still be off by 2-3 mph.
davins130
424
  • Nov 1, 2004
i did switch the speedo gear, and it still is about 3 mph off. thanks a lot for the help
95Vert
1,785
North Mexico (deep south Texas)
Nov 1, 2004
  • Nov 1, 2004
It's still going to be off with the speedo gear, right around 3-5 mph(I think). Just turn the wheels once, and see how many times the d/s turns (make sure to mark both). This way you'll see what gears you installed, a little over 4 d/s turns means you have 4.10s, and so on. BTW, how's the launch??
davins130
424
  • Nov 1, 2004
i was really expecting a much bigger difference with 4.10's, but its still fine. gas mileage didnt change much at all, and people said i'd be able to spin my tires from like 15 mph, but i can hardly get them to spin from 5.
scarless
175
  • Nov 1, 2004
You just need more power!
95Vert
1,785
Nov 2, 2004
  • Nov 2, 2004
check to see if they are 4.10s
willys1
1,004
New Jersey
Nov 2, 2004
  • Nov 2, 2004
Its more then 3-5. Its 1mph off for every 10mph your going.If you going 20,,your really doing 22. If your doing 60,,your really doing 66!! At 2500rpm's,,Im doing 72mph.Sorry,its the other way around.If your doing 22,your really doing 20.,,And if your doing 66,your really doing 60 ,ect,,,,,,They dont make a gear for 410's.The biggest you can get is a 23 toothed speedo gear,and thats for 373's.At least thats how AOD's are!!
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Engine Bad vibration 3500 RPM+
  • Vulpes5.0
  • Sep 8, 2021
7K
Fox 5.0 Mustang Tech Sep 22, 2021
Vulpes5.0
E
92 Fox Aod Sloppy In 4th Gear
  • EZE183
  • May 7, 2016
Fox 5.0 Mustang Tech May 7, 2016
EZE183
E
D
Aode Slow 1st To 2nd Under Wot
  • Dacon
  • Aug 9, 2014
3K
1994 - 1995 Specific Tech Aug 11, 2014
Dacon
D
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
