  • 1994 - 1995 Specific Tech
AODE to T5???
  • Thread starter Thread starter oosmytoo
  • Start date Start date Mar 12, 2004
O
oosmytoo
530
Portland - Oregon
Mar 12, 2004
  • Mar 12, 2004
im wanting to convert my auto into a 5 speed real soon and im trying to piece together everything i need to do so.. hoping you guys could help me out? so, what do i need? and will a t5 out of a 93 or older work with our car?
M
mustangman33
262
Chicago, IL
Mar 13, 2004
  • Mar 13, 2004
t5 to auto swap
Hey man, take my advice, stick with your auto, I have a 95 with a 351W, pushing out about 450hp\415torque, with the stock t5, and it went out on me, I'm still tring to find some performance parts for it, about 4 months, now it is in the shop and they say that it will cost around 1500 to rebuild, but the heavy duty upgrade will only hold around 335tq, Ive went to serveral transmission shops and they all turn me around, and they say good luck on finding some more gears for that thing, so instead of going through all of the hassel, I'm putting an auto in it
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Mar 13, 2004
  • Mar 13, 2004
aode to t5 swap
I did this a while back on my car. Got a kit from Mustang Parts Specialties, a bit pricey, but it came with everything. From what I can recall you'll need: the tranny, pedal assy, bellhousing, driveshaft, shifter+bezel, cable+fork, flywheel, clutch, pilot bushing, x-member and a 5-speed computer. It wasn't a bad job, hardest part was pulling that heavy AODE out of the way. It ran on the AODe computer for a while but drove funny. Not sure but I think the T-5 from 93 will work, but some of the supporting equiptment might not. Good luck.
R
rb69
26
  • Mar 13, 2004
I not sure that I can answer your question, but I bought a 95 that had a AODE as a stocker and the fellow swapped a manual into it. When I bought it both trans. where gone, but I have the 95 bellhousing,pedal assy,steeda quadrant,firewall adjuster & cable, flywheel from the swap.Interested??
I was told that 94-95 bellhousing is a must to corectly postion the shifter.
deadly97snake
592
Manchester, NH
Mar 14, 2004
  • Mar 14, 2004
When I bought my conversion I bought it from a shop that buys totaled mustangs and sells the parts. I got a whole conversion kit (minus the clutch) for $800.00. It was inside a 95 GT that only had 48,xxx miles on it and in the end it ran perfectly.
M
mustangman33
262
Chicago, IL
Mar 14, 2004
  • Mar 14, 2004
Do you guys have problems with your manual tranmissions, because I'm thinking about going to an aode, because I would like to keep my t5, but want it to handle my torque, cause I'm in the process of adding nitro, any suggestions on t5 rebuild kits and gears??? please help
mr_woodster
1,314
Riverside, CA
Mar 14, 2004
  • Mar 14, 2004
why would an AODE be bette for your torque, usualy the T5's are known to be bullit proof in and around 300-350 tq if i recall correclty from the factory standards?
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
