  • 1994 - 1995 Specific Tech
AODE tranny not shifting
  • Thread starter Thread starter 5.0wnes
  • Start date Start date Jan 28, 2008
5.0wnes
  • Jan 28, 2008
after i bought my 94 mustang GT, the tranny was shifting fine. i decided to do a tranny flush because it was sitting for more then 4 years but when i did a tranny flush all of a sudden the tranny wouldnt shift. it would take off but when the rpm goes really high it wouldnt shift. i was thinking since i did the flush without changing the filter on the tranny i could have a plugged filter. does anyone know would could have happened? thanks for the help guys.
drakesdad
961
Oregon OHIO
Jan 28, 2008
  • Jan 28, 2008
why wouldn't you change the filter.....lol......all the years there becomes build up in certain areas of the trans...and if it was not flushed reguarly.......it cakes up...when you flushed it it could have broken loose and clogges up in the valve body.....or somewhere...I would have it flushed once more and change the filter.......that would be my first move....and I would do it quick and stop driving it until then..
also...fill it with synthetic.......and change it after a while.....but beware...sometimes synthetic will reveal a leak or two...
Zero_chance
1,244
Maricopa, AZ
Jan 29, 2008
  • Jan 29, 2008
How did you flush it? Machine? Dropping the pan? Drain the converter? Did you fill it back up with at least 12, sometimes as many as 14 quarts?
5.0wnes
  • Jan 30, 2008
i flused it wit ha machine
gcomfx.com
3,690
Republic, MO
Jan 30, 2008
  • Jan 30, 2008
For sure change that filter. It's probably REALLY filled up now.
SilverFoxbody
149
  • Feb 1, 2008
I would be sure it is full, yes, and check the codes as well.
Make sure to use Mercon V as well on service.
Could be VSS or MLPS sensor.
Note that defualt is 2nd gear, so let us know if it is running up in 2 or 1.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
