  • 2005 - 2009 Specific Tech
Approximate E85 BSFC?
  • Thread starter Thread starter enyawix
  • Start date Start date Mar 23, 2008
enyawix
507
Mar 23, 2008
  • Mar 23, 2008
What would a approximate BSFC be for E85? I am in the home work faze of an E85 engine build.
M
myfirstii
401
chicago,Il.
Mar 23, 2008
  • Mar 23, 2008
This should help.....
Estimating fuel injector, carburetor and fuel pump requirements
Fuel injector, carburetor jet sizing, and fuel pump requirements can be estimated by using the following rules of thumb as a starting point. For a naturally aspirated (NA) engine (carbureted) on gasoline most need a brake specific fuel consumption (BSFC) for gasoline of 0.50 lb/(hp·h). On E85 the same NA engine would need a BSFC of about 0.65 lb/(hp·h).
Turbocharged engines typically need BSFC fueling of about 0.60 lb/(hp·h), a reasonable first guess for fueling required on E85 would be 0.77 lb/(hp·h).
For a simple conversion to replace gasoline with E85 take the current "flywheel horsepower" as a reference point. With E85, power should increase by about 5%, so the estimated E85 fueling would be:
(BHPgasoline x 1.05) x BSFCe85 = Estimated E85 fuel requirements.
This site might be a help. www.billdoll.com/dir/science/energy/ref/ae/be/e85.html
Patrick
C
COBESGT
231
Dubuque, Iowa
Mar 24, 2008
  • Mar 24, 2008
If a person wanted to go to E85, what parts would have to be changed?
Fuel pump, fuel injectors, custom tune???????
enyawix
507
Mar 24, 2008
  • Mar 24, 2008
Say you are shooting for 300 wheel hp
stock fuel pump is ok 36lbs injectors
You need to add 46% more fuel to your tune
I would also set base time to 15 BTDC
My issue is turbo cars use more fuel and I do not know how much fuel to add. I know BSFC will be higher but how much? The math for E85 is below
(14.7 / 9.7) * (Engine HP * BSFC) / (Number of Injectors * (Injector duty cycle*100))
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Mar 24, 2008
  • Mar 24, 2008
The dyno shop I got to may be able to help. They have a 750+rwhp turbo Talon that they've tuned for E85, and they've tuned a few other E85 cars. I don't know how willing they would be to give out any information, but it's worth a shot.
Their name is Rev Hard Inc. 877-RHI-DYNO. Trent or John are the guys you need to talk to. Trent's the owner of the Talon.
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
J
Fuel pump help
  • Jschal
  • Mar 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2025
AeroCoupe
Fuel SN95.0 fuel system
  • RedFury5.0
  • Apr 22, 2025
Fox 5.0 Mustang Tech Apr 22, 2025
AeroCoupe
