Fuel pump help
Jschal
WI
I'm not sure if this is the right area to put this thread. But I need some help finding the right pump for my car.
Lookin to make about 700 wheel on E85 with my sbf. I've been looking everywhere and need help finding a fuel pump that will support at least 800hp on E85 with a turbo
Only reliable thing I could find is the aeromotive pro series but those are far to expensive and way overkill.
What are you guys running or what pump do you recommend I run for that goal. Preferably Looking for part numbers or links to a specific pump.
You could go with dual walbro 450 pumps. Might be able to use a modified cobra pump hanger assembly and a cobra style fuel tank. The outlet size may need modification for your size fuel lines.
I don’t want to assume anything here but are you putting this in a Foxbody and if so what year? Will the car be injected or a blow through carb setup? Do you want to keep the stock tank? Are you going to run aftermarket fuel lines, regulator, and if injected fuel rails?
What I am driving at is we need to know the car and all the other details to help. There are some smart folks on here but you have to help them help you.
